I've added 1.6-1 roller tip rockers to my otherwise stock 120k mile L83. Auto, 3.07's, and cold air mod w/K&N. At Houston Raceway Park at 68F and almost sea level:
14.7@92mph followed by the same 2 more times. Previous best was 15.2@89-the rockers really make a difference!
JD, is this your whole NA mod list? Borlas, K&N Cut lid, AFPR, HO Coil, Low Temp fan switch, 180 Stat
Its missing the long tubes - Drag Radials and the free mods - the post in Coasters spreadsheet should show that stuff
Originally Posted by rel3rd
For your nitrous runs, is that a wet kit or dry?
Wet - NOS plate - but I added a lot of essentials like a 6al etc - I wouldn't go 150 shot without safeties - what I am trying to say is do not think you can do this for 500 bucks add another 1k at least
I went to the Sacramento Raceway today 2/17/07 and made three runs. Last year the fastest run was 14.1. I changed two things before going to the track today. I installed March under drive pulleys and I pulled the cat (for today only) and installed a straight thru BIG PIPE I built myself. All other things are the same as last year, except I now have 214,000 miles on the car.
1st run
60 ft 2.092
1/8 8.747 @ 80.545
1/4 13.613 @ 99.478
2nd run broke out the rear end bad and shut it down
3rd run - dropped street tire pressure to 26
60 ft 2.122
1/8 8.808@ 80.649
1/4 13.663 @ 102.395
Here's my latest best ("silver" on the left) for the list after installing EM long tubes and random tech high flow cats... My best 1/8 mile time is in my sig
[IMG][/IMG]
