Turn Signal/Tail Lights - Rewiring for European standards
Tibor
Hi guys.
I am in a C4 1994 tail lights modification to European way, but I am struggling due to my new brake-only lamps (center and inner ones connected together) because my all tail brake lights still come up IDK how is it possible? Brake switch white wire unplugged( which come from brake pedal switch to turning switch). The outer lamps brown wires have been cutted, and the yellow and green wires( which are the brake controlled turn signal) from the outer lamps to the inner lamps also have cutted. The outher lamps flashing so thats good, no tail light on those also good , but my brake light are still come on at the outher amber lights. So my brake line is till on the side green and yellow wires even is disconnected from the indicator switch.
Any thoughts? Thanks : Tibor
