TPS Drama....
Old May 5, 2006 | 12:23 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Default TPS Drama....
My '85 has gone through 3 throttle position sensors in a little over a year and a half. Just got a call from DB Performance that the TPS is bad (and it was a AC Delco part) that I replaced not too long ago. What could be causing this? Anyone else have a similar experience out there? Any help would be appreciated. Trying to get her ready for the Cruise-In!
Old May 5, 2006 | 12:27 AM
Red Tornado's Avatar
Red Tornado
i went thru 2 of them (ac delco) in the last year myself. it was contributory to a faulty idle.
maybe this is a suck-azz part like the damn slave cylinders we all know and love.
Old May 5, 2006 | 07:00 AM
mseven's Avatar
mseven
Did it throw a code (21, 22) ? could be faulty connections, shorted sensor ground (dk. blue wire or gray), and or, ecm connection
Old May 5, 2006 | 07:10 AM
RRT vette's Avatar
RRT vette
either one of these could cause a TPS or any sensor to take a dump.
Old May 5, 2006 | 08:17 AM
JackDidley's Avatar
JackDidley
Could a worn out shaft in the TB be causing this ??
Old May 5, 2006 | 08:47 AM
H P Bushrod
Moderator Emeritus
Yes, before I took it in for it's engine mods, I got a code 22, with the new Delco TPS. Frustrating.
Old May 5, 2006 | 09:19 AM
rick lambert's Avatar
rick lambert
with mseven and RRT, connections or bad wire.
Old May 5, 2006 | 10:26 AM
Red Tornado
yes, codes and a visual check are the first to do......in my case the sensors themselves took dumps. this is just fyi.
Old May 5, 2006 | 10:37 AM
mseven's Avatar
mseven
I would also inspect throttle and linkage to see if it is hanging up in anyway
It will throw a 22 (low voltage)if the volts are less than .24. If that's set between .54 -.62. An open or short in the blue or grey wire will throw a 22.
I would begin with the weather pack connection, good clean connection etc. Get a VOHM meter it is easy to check. Disconnect sensor, jump the blue and gray wire should give over 4. volt. If not check blue wire for signal w/test light to battery power should show 4. volts. If yes, grey wire open or shoted to ground, connector or faulty ecm. If no, blue is shorted to sensor ground circuit (tps, cts, oil temp, all on same ecm ground, black wire) faulty ecm connection or ecm.
Usually it holds the TB blade open, when vac. decreases closes. It could also be sucking air in, either way raisng idle. The tps will increase its reading as the throttle angle is increased.
The TPS should be set static w/engine off (0% throttle angle), key on. If it were the shaft/bushing, I would suspect a higher v.reading (possibly code 21). Visual is still good, as kinkage, cable etc. may be held up or sticking at static position. Then being set to .54, and after car runs drops below.24 is possible.
Old May 5, 2006 | 10:40 AM
RRT vette's Avatar
RRT vette
It makes it a little hard for me to believe that 3 TPS sensors would go bad with a properly working circiut or connections. Maybe..1 but 3... no. IMO I would check the connections TPS and ECM or circuit for being grounded, thus frying the TPS sensor.
Old May 5, 2006 | 11:52 AM
CFI-EFI's Avatar
CFI-EFI
Don't shoot the messenger. It sounds as though people have been bandaging symptoms rather than diagnosing and treating the disease (cause).
RACE ON!!!
Old May 5, 2006 | 03:22 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
.... and then there is my TPS that has been cracked, new hole tapped after breaking the corner off and the whole thing is kind of rigged on, yet it runs perfectly
Old May 6, 2006 | 12:46 PM
LWesthaver's Avatar
LWesthaver
My '85 has gone through 3 throttle position sensors in a little over a year and a half...
Here's a little bit of info I put together about a TPS problem I had:
TPS Diagnostics
I hope this helps!
Old May 6, 2006 | 06:47 PM
H P Bushrod
Moderator Emeritus
TPS Diagnostics
I hope this helps!
Thanks for your replies. It's greatly appreciated!
To TPS Drama....
