How to reprogram for new rear gears.
1 Post
St. Jude Donor '05
I have a 95 VERT A4 (4L60E tranny with 3.07 rear gears). I am looking to get an upgrade to 3.54 or 3.73 rear gears. Assuming I go ahead with this, does anyone have experience with this, and know how to reprogram the proper shift points needed to compensate for the rear gear change. Rear tires are stock.
Originally Posted by RAGOVET
Anyone use FASTCHIP to have their computer reprogrammed for rear gears or other tuneups?
Also, use this site here: http://www.f-body.org/gears/ to figure out what sort of speeds you want to set for each gear, if you select 93-97 F-Body A4 this will bring up the transmission ratios, then just manually fill in the tire size and rear end ratio.
