Alternate p/n for wheel bearings, pics, cheaper prices...
#41
I know most people are talking about specs, but just to put it out there... on ebay I bought both Timken and AC Delco hub bearings for cheap.
The Timken rears came directly from the factory in Tennesse I bought them for @ 150.
And the AC Delco fronts came directly from the warehouse for 170.
So if any of you still want these names they are more affordable than previously posted and they come directly from the factory/warehouse not to mention the original waranty
#42
If you wanna use the less expensive ones, Ahhhh, **** it and take the damn ABS off and simplify your life a bit more! Less brake/electrical problems to worry about!
#43
Received 3,043 Likes
St. Jude Donor '05
When removing them, doesnt it take a T55 torx socket from the rear? I cant find one larger than a T50
#45
Cruise-In VII Veteran
You'll also need a 36mm socket and a torque wrench that can read up to 163 (IIRC?) foot pounds. I rented the torque wrench because out of the 3 I have, the biggest one only goes up to 150 ft-lbs.
#46
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by Dave89CC2
I got my T55 socket at Sears - but it's not a Craftmans, its a Lisle (made in USA). It's not with the other sockets, it's with the automotive specialty tools (compression testers, bearing pullers, etc.). It was only about $6-8.
I bought a 150 ft-lb tq wrench from harbor frieght, and the end busted off at about 120.
#47
St. Jude Donor '05
Have to go back to Sears, Osh and Harbor Freight didnt have em. Got the big nut off the bearing last night, wasnt too bad. Bought an awful lot of "one time use" tools for this car
Ill get the brand and PN for the rears I used to add to your list.
#48
84-85 Corvette Front: 513019 or 513009 or 513090 or 513085
86-90 Corvette Front: 513019
91-96 Corvette Front: 513085 or 513090
84-96 Corvette Rear: 513020 or 513013
Do not, under any circumstances, buy cheap bearings from China or "Ali-Baba"
Read further for applications, alternate p/n's, and prices.
"AZ" means Autozone
"P/A" means Parts America, Kragen, Checker, Schucks. Prices for these vary by region.
-----------FRONT BEARINGS------------
513019 84-90 Corvette front PICTURE (BCA)
5x4.75 FlangeDia=5.78 WheelPilotDia=2.76 BrakePilotDia=2.78 FlangeOffset=2.72 HubPilotDia=2.83 Flange=Rectangular (Front wheel has ABS with tone ring sensor)
ACDelco #FW115 . Rockauto.com=$280
Timken/BCA #513019 . Rockauto.com=$165, AZ $175+1yr, P/A=$179-$240+1yr
SKF/CR #BR9300023 . P/A=$240+1yr
GM #12413041 . gmpartsdirect=$314
513009 82-84 rear Buick Riviera/Caddy/Olds w/disc brks PICTURE (BCA)
AC Delco #20-2 . Rockauto.com=$231
Timken/BCA #513009 . Rockauto.com=$137, AZ=$88+1yr, P/A=$198+1yr
SKF/CR #BR930088 . Napa=$179, P/A=$194+1yr
GM #7470539 . gmpartsdirect=$243
513085 91-96 Corvette front PICTURE (BCA)
5x4.75 FlangeDia=5.79 WheelPilotDia=2.76 BrakePilotDia=2.78 FlangeOffset=2.72 HubPilotDia=2.83 Flange=Rectangular (Front wheel has ABS with Integral Sensor)
AC Delco #FW109 . Rockauto.com=$351
Timken/BCA #513085 . Rockauto.com=$300, AZ=$185+1yr, P/A=$269-$456+1yr
SKF/CR #BR930065 . P/A=$424+1yr
GM #12413001 . gmpartsdirect=$369
513090 93-02 F-bodies, 97-00 S10 PICTURE (BCA)
5x4.75 FlangeDia=5.79 WheelPilotDia=2.76 BrakePilotDia=2.78 FlangeOffset=2.72 HubPilotDia=2.79 Flange=Rectangular (Front wheel has ABS with Integral Sensor)
AC Delco #20-86 . Rockauto.com=$214
Timken/BCA #513090 . Rockauto.com=$165, AZ=$112+1yr, P/A=$115-$260+1yr
SKF/CR #BR930052K . Napa=$181, P/A=$136+2yr
GM #7470587 . gmpartsdirect=$230
Dynapak #513090 . P/A=$105+1yr
----REAR BEARINGS----------
513020 84-96 Corvette rear PICTURE (BCA)
5x4.75 FlangeDia=5.689 WheelPilotDia=2.761 BrakePilotDia=2.781 FlangeOffset=1.861 HubPilotDia=3.209 Splines=27 Flange=ModifiedTriangle
AC Delco #20-45 . Rockauto.com=$260
Timken/BCA #513020 . Rockauto.com=$152, AZ=$155+2yr, P/A=$179-$240+1yr
SKF/CR #BR930024 . Napa=$208, P/A=$160+2yr
GM #7470501 . gmpartsdirect=$293
wheelbearingsinc.com = $65
513013 83-93 S10/Blazer 82-85 front Buick Riviera/Caddy/Olds PICTURE (BCA)
5x4.75 FlangeDia=5.69 WheelPilotDia=2.76 BrakePilotDia=2.78 FlangeOffset=1.86 HubPilotDia=3.21 Splines=27 Flange=ModifiedTriangle
$61 at wheelbearingsinc.com
AC Delco #20-52K . Rockauto.com=$253
Timken/BCA #513013 . Rockauto.com=$144, AZ=$143+1yr, P/A=$135-$227+1yr
SKF/CR #BR930052K . Napa=$87/$208, P/A=$123+1yr
GM #7470005 . gmpartsdirect=$301
Dynapak #513013 . AZ=$75+1yr
wheelbearingsinc.com = $61
There's also a handful of bearings that will fit but change your rotor and wheel offsets a bit.[/QUOTE]
Especially about the made in China part!!!!!
A good friend of mine used to work for a bearing supply company, and they were always about 20% cheaper than the Auto Parts stores, even before my discount. Not sure if they would carry the hub assemblies or not, but worth a try. All you needed was the above bearing numbers to look them up. Another possible avenue for you to explore in your area.
"AZ" means Autozone
#51
Originally Posted by Draven
New update:
wheelbearingsinc.com is still around, just their website is town.
-Joe
-Joe
If the website is down, how do you get ahold of them or their replacement parts?
#53
WBI# 1-866-482-8648
I had a thread earlier this summer on this subject
http://forums.corvetteforum.com/show....php?t=1431211
still haven't ordered mine yet, probably going with Wheel Bearings inc
#57
Whats the big deal, those are morre expensive than the other online sources.
If anyone gets prices quotes from carquest, pepboys, superior chevy, or any other place that doesn't have an online catalog, let me know and I'll add em to the list.
#58
St. Jude Donor '03 & '05
http://www.partsamerica.com/ProductL...ing%2C%20Front
Forget this crap, 455 bucks now!!! 1/09/07
#59
Has anyone tried a 513013 rear bearing on an 84-96?
I noticed the thread started out mentioning it might work then listed it will. I checked prices and oehq has the ac delco 513013 for $167 while the 513020 is $250.
