Where are MAF relays located on 1988 Corvette?
Where are the 2 MAF relays (power and burn off) located in the engine compartment of the 1988 Corvette? Also what are part #'s of the relays?
Correct, above and behind the battery. Power relay is facing forward and the Burnoff is facing to the right. Not sure of the part # but at Autozone the relay is MR22.
The 1988 Corvette had the same MAF relays on both MAF Control and MAF Burn-off - GM# 14103304 5-pin, but had different plugin's a 5pin for power control and a 4-pin for burn-off.
MAF Burn-off 4-pin is notorious for throwing a GM code 34 error when EBL ECM is converted over to MAP Sensor!
Reference:
https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-intermittent-no-start-cranks-replace-mass-air-flow-relays-534.html
https://www.yoyopart.com/oem/12315410/gm-14103304.html
https://www.oreillyauto.com/detail/c/standard-ignition/lighting---electrical/relays/fuel-emission-relays/mass-air-flow-sensor-relay/5c7f1e4f7a1d/standard-ignition-30-amp-5-terminal-multi-purpose-relay/std0/ry109/v/a/3208/automotive-car-1988-chevrolet-corvette?q=mass+air+flow+sensor+relay&po s=1
https://www.oreillyauto.com/detail/c/masterpro-ignition/lighting---electrical/relays/fuel-emission-relays/mass-air-flow-sensor-relay/5c7f1e4f7a1d/masterpro-ignition-30-amp-5-terminal-multi-purpose-relay/mpi0/2dr1042/v/a/3208/automotive-car-1988-chevrolet-corvette?q=mass+air+flow+sensor+relay&po s=0
Reference:
Reference:
Reference:
IHBD (09-18-2022)
I don't 'understand' this post in a thread that seemed to have all correct information and is 16 years + old. Your referenced part # was replaced by GM over 20 years ago by the part # in post # 4. Poster #3 had the correct location as well. The thread OP expressed gratitude 16+ years ago. I just don't 'get it'.
Just doing some research for my EBL ECM error code 34 that converts to a MAP Sensor using the MAF Sensor wiring, seeing a lot of controversy in other forums on MAF relays, and thought I would put some links found to substantiate this posting for the 88-89 Corvette!
