AC Noise
Old Jul 6, 2006 | 01:19 PM
scott89's Avatar
scott89
Default AC Noise
What would cause my belt to squeal when I turn on my AC? It stops after 30 seconds or so. I still have my frisbee on (1989 L89). Does something have to be lubed on the compressor or other component?
Thanks in advance.
Old Jul 6, 2006 | 02:46 PM
SunCr's Avatar
SunCr
Wrong belt size or worn out tensioner (check the alignment marks); worn compressor (outer hub should turn the shaft with minimal resistance with it off); too large of an air gap between outer hub and pulley causing it to slip (specs are .020 - check it with it off).
Old Jul 6, 2006 | 03:03 PM
scott89's Avatar
scott89
Belt is correct and the compressor hub does spin with little resistance. I'll check the gap and tensioner tonite. Where are the alignment marks?
thanks
Old Jul 7, 2006 | 12:18 PM
SunCr's Avatar
SunCr
It's marked on the Tensioner - a couple of lines indicating range, but it can be a bit confusing - hopefully someone will post a pic.
Old Jul 7, 2006 | 02:47 PM
scott89's Avatar
scott89
thanks again
To AC Noise
