C4, Kent-Moore Spring Tool Question
Old Jul 13, 2006 | 09:39 PM
LS6 Motor's Avatar
LS6 Motor
Default C4, Kent-Moore Spring Tool Question
Does anyone know where I can get the tool shown in the FSM for removal of the front, and rear springs on a C4. It is a Kent-Moore tool, and obviously the local Chevy Dealships aren't going to loan theirs out. I talked to a local Snap-On dealer who said he could get me one, but, after three phone calls which he never returned, thats a dead end. I did a search for Kent-Moore on the internet, and found out it is part of the SPX Coproration, but I'm not sure if they will sell to an independent individual as their offices are closed right now. I thought I would give you guys a shout to see if anyone has been down this road before.....Thanks!!
Old Jul 13, 2006 | 09:45 PM
aminnich's Avatar
aminnich
I changed the rear spring on mine and did not need any special tool. Maybe there is a tool for the front?
Old Jul 13, 2006 | 09:51 PM
LS6 Motor's Avatar
LS6 Motor
It is the same tool for the front, and the rear. I know the trick with a floor jack to do the back spring, but, I don't feel good about it with the fiberglass spring. The tool I'm looking for is apparently only a couple hundred dollars, which is better than nicking a three hundred dollar spring. As far as the front, there is no way I would try that because the spring sits in the bottom control arm which I want to remove on both sides to do all the bushings, and ball joints.
Old Jul 13, 2006 | 11:32 PM
bogus's Avatar
bogus
the jack trick will work for the front, too. Just take the front end apart one piece at a time, and do the spring last...
Old Jul 13, 2006 | 11:45 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've probably done this about a half dozen times by now with the floor jack. Use jack to unload spring, remove everything attached to it, then lower it. Put the jack under the lower control arm, use a rubber pad to protect the aluminum, and put it just inboard of the ball joint. Also keep the jack lined up with the spring, otherwise you'll side load it and it'll shoot out and break your ankle.
I've never heard of anyone using the tool, and I doubt any GM dealer this side of the mississippi will have it either.
It's just not needed. The factory service manual is chock full of special service tools that simply aren't necessary.
My 4 speed required about 15 special GM tools to rebuild it. I used zero of them. You could have been finished by now.
Old Jul 13, 2006 | 11:48 PM
froggy47's Avatar
froggy47
Did front & rear no special tool, just be DAMN careful, eating a loaded spring or a flying floor jack WILL spoil your day.
Old Jul 13, 2006 | 11:55 PM
LS6 Motor's Avatar
LS6 Motor
Exactly, which is why I will find this spring tool! Oh yes, ALL the Chevy dealers have them, or at least the ones here in Rochester do, (Bob Johnson, and O'Connor Chevrolet). Would you really want someone doing warranty work on your new $55,000 C6 using a floor jack, I know I wouldn't?
Old Jul 14, 2006 | 12:09 AM
96GS#007's Avatar
96GS#007
Kent Moore tools are only available from them or used on E-bay. Do a search, they have a website with a phone number.
I always use the floor jack.
Old Jul 14, 2006 | 12:13 AM
5pinball's Avatar
5pinball
try ordering it from your chevy dealer then or make your own
Old Jul 14, 2006 | 01:07 AM
Great White North's Avatar
Great White North
Old Jul 14, 2006 | 01:10 AM
bogus's Avatar
bogus
think about this statement for a minute... you are willing to lift a 3000lb car with said floor jack, but hesitate using it on a 500 inch-lb spring.
If the floor is safe for the jack, it's safe for the spring.
Follow CC's advise and save the $$$.
Old Jul 14, 2006 | 01:24 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
I sent you a pm on how to buy this tool, call OTC at 1-800-533-6127
they sell Kent Moore, OTC is the parent company and they sell to everyone for list price.
Old Jul 14, 2006 | 01:56 AM
VenkmanP's Avatar
VenkmanP
I punched "kent-moore tools" into google, and in <30 sec I had their phone number as well as this note:
Special service tools are easy to purchase and are available to the general public by simply contacting SPX KENT-MOORE by phone, fax or mail.
Along with that I also got several hits for auto parts dealers that carry the K-M tools.
Old Jul 14, 2006 | 02:59 AM
LS6 Motor's Avatar
LS6 Motor
Bogus, not to be sarcastic, but, I have seen one of these jump off a floor jack. Picking up a car on a particular lift point is one thing, using a floor jack against a spring on an awkward angle that is preloaded is another. I guess to each his own, I just don't elect to do it that way, which is why I asked the question regarding this tool. Thanks, JD + VIS for the information!!
Old Jul 14, 2006 | 03:19 AM
the blur's Avatar
the blur
at least we'll know where to borrow the correct tool from
Old Jul 14, 2006 | 09:46 AM
bogus's Avatar
bogus
news to me... I have used the jack technique with zero problems.
good luck with the tool.
Old Jul 14, 2006 | 08:13 PM
LS6 Motor's Avatar
LS6 Motor
Scratch the tool, over $800 from the two places I called so that isn't happening. I guess I will try the floor jack method. It doesn't worry me so much doing the rear spring, it is front I'm concerned about. At any rate, if you never hear from me again, assume I ate a floor jack or the control arm.......
To C4, Kent-Moore Spring Tool Question
Old Jul 14, 2006 | 09:54 PM
JD'S WHITE 93
I don't know if this would work without getting under the car but it's an idea at least. I remember doing coil springs and running a chain through the spring in case it tried to jump out and kill me. Couldn't you wrap a chain around the monoleaf and chain it to something so if it lets go it doesn't smack you in the face ?
Old Jul 14, 2006 | 10:42 PM
LS6 Motor's Avatar
LS6 Motor
That might not be a bad idea. I spoke to a couple of machinist where I work, and showed them the pictures in the FSM. They didn't think it would be a big deal to make the brackets, and then it is just a jack bolt in between that releases the tension.
Old Jul 14, 2006 | 10:46 PM
CentralCoaster
The non-z51 spring may be difficult because as it extends down, the control arms go down to a pretty steep angle. This makes the jack difficult to keep under it. It's not so bad for lowering it, but for compressing it back up, it can be tough to get the jack started.
You may need to remove the grease fitting from the lower ball joint then jack from there.
Also you will need to get the front end up pretty high in order to get the spring to full droop.
Once its at full droop, simply push down on the control arms to unslip them from the spring ends.
And make absolutely sure, you disconnect the sway bar, shock, and spindle from the lower control arm before letting it down. Otherwise the spring force will overextend the upper ball joint and damage it.
And keep in mind the shock is ultimately what limits the suspension droop.
