85 TPS sensor issue.
Old Jul 18, 2006 | 06:47 PM
black85vette's Avatar
black85vette
Default 85 TPS sensor issue.
I went through the procedure listed for setting my TPS and adjusted it so it read .54 closed so the procedure said to check it also at full throttle i removed the plastic tube going the air filter and verified that the blades were fully open it only reads 4.7 volts! what next?
Old Jul 18, 2006 | 06:57 PM
CFI-EFI's Avatar
CFI-EFI
Close enough. Put it back together and worry about a REAL problem.
RACE ON!!!
Old Jul 18, 2006 | 06:58 PM
rick lambert's Avatar
rick lambert
Old Jul 18, 2006 | 07:30 PM
black85vette
RACE ON!!!
OK
Old Jul 18, 2006 | 07:39 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Good volt numbers,just under the magical 5 most never see!
You did know you can advance your tps abit more,I think up to .64 or so for an slight increase in power,or of throttle response,I forget which claim it is.Cant go too much or shat happens.
I think 65Z01 has something on his website about it too.Dont think you need it though with your settings being close to dead on.
Old Jul 18, 2006 | 11:04 PM
ED HEISER's Avatar
ED HEISER
I have tried different settings, and ended up going back to .54. Higher numbers gives faster throttle response but makes it idle too high and erraticly. You can accomplish the same feeling of more power by giving it more gas faster. I try to drive smoothly most of the time now that I had it for a year and only jump on it occasionally. Hopefully it will last longer than hot rodding it all the time.
Old Jul 18, 2006 | 11:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
4.7 is plenty. I think 4.1v is all you need for the computer to see wide open throttle.
Old Jul 19, 2006 | 12:36 AM
86PACER's Avatar
86PACER
I've played with mine at .54 and .64
The thorttle response is noticeably better at .64
Old Jul 19, 2006 | 01:39 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Best performance for mine is at .58.. not much , but enough
Old Jul 19, 2006 | 02:58 PM
CFI-EFI's Avatar
CFI-EFI
Actually, the TPS voltage only affects the engine's reaction to the throttle; throttle response. It does not give the car one more ounce of horsepower or torque. There is no increase in performance. When I was experimenting with mine, I found it difficult to maintain a steady highway speed with the voltage set too high, too sensitive. If you like the way it feels, go for it. Just don't think you have accomplished something you haven't.
RACE ON!!!
Old Jul 19, 2006 | 03:09 PM
RRT vette's Avatar
RRT vette
Put it all back together and know it is correct.
Anytime you move the postion of the throttle plates, it will change the voltage of the TPS.
Old Jul 19, 2006 | 03:10 PM
scorp508's Avatar
scorp508
69% of 5.0V is considered full throttle to the ECM. At least in 1987 it was.
To 85 TPS sensor issue.
