Tire beads broken?
Old Sep 6, 2001 | 02:21 PM
baddreams's Avatar
baddreams
3rd Gear
Default Tire beads broken?
Hello everyone, this is my first post. I don't have the 'vette, my step dad does, but since he couldn't use a computer if his life depended on it, I'll ask the questions for him
He has a '90 (C4 I guess) and he has been getting flat tires while the car sits there. He took it into the shop and they told him that the beads are not holding. Has this type of thing ever happened to anyone, and is there a cure? The tires he has are P275 40Z R17, and I can't remember the damn brand! :rolleyes: It's like, Fulker or Falker, or something like that.
Anyhoo, perhaps someone can shed some light. If no one can, then what are some good tires to get for it?
Thanks!
Old Sep 6, 2001 | 02:42 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Default Re: Tire beads broken? (baddreams)
Did he have them removed, cleaned, and remounted? I've had a different car (not the vette) in a ditch before and had to get the "beads" cleaned so they would hold air before. Worth a try...
Cory
Old Sep 6, 2001 | 02:44 PM
ZylaRace's Avatar
ZylaRace
We'll need the rim size info.
17"x11"
17"x9.5"
etc.
(Double check the year. Are the rims stock?)
I'm guessing he has the wrong rubber on the wrong rim.
Old Sep 6, 2001 | 02:50 PM
baddreams's Avatar
baddreams
3rd Gear
Default Re: Tire beads broken? (ZylaRace)
It's a '90 for sure, and it has the stock wheels.. Those things are wide as hell, gotta be 11's right? So do 275 40's fit on 11's?
Old Sep 6, 2001 | 03:01 PM
ZylaRace's Avatar
ZylaRace
A regular 90 came w/ 17"x9.5" front and back. The 90 ZR1 came w/ 17"x9.5" front and 17"x11" in the back.
Old Sep 6, 2001 | 03:05 PM
ZylaRace's Avatar
ZylaRace
The stock size tire for the regular 90 is 275/40-17.
Look at the lastest (there is always one) "What rubber should I get" thread. http://forums.corvetteforum.com/zerothread?id=144097
[Modified by ZylaRace, 1:06 PM 9/6/2001]
Old Sep 6, 2001 | 03:07 PM
baddreams's Avatar
baddreams
3rd Gear
So it probably has the correct size tire, but why would it be losing air around the bead? He took it into the shop and they put some gunk in the tire to try to stop it, which didn't work.. Now he just wants to know if this is fixable or if he needs new tires
[Modified by baddreams, 8:02 PM 9/6/2001]
Old Sep 6, 2001 | 04:02 PM
ZylaRace's Avatar
ZylaRace
Hard to say w/o seeing the wheel.
Basic stuff the shop guy should have done:
Is the rubber bead damaged?
Is the rim dented?
Is the rim bead seat clean and unmolested?
Is it not just a bad valve stem?
Are they sure the bead is leaking? Put it in some water (The Pacific will work here) and follow the bubbles.
There is some tire goo that can be spread on the rim seal to get a better seal.
To Tire beads broken?
