Coolent Bleed Valve Stripped
Old Aug 22, 2006 | 06:01 PM
rickneworleansla's Avatar
rickneworleansla
Default Coolent Bleed Valve Stripped
Does anyone have the part number for the coolant bleed valve that is on the top of my 95's thermostat housing? Mine is stripped. I called a local Chevy dealership and they said the part number was 10071707 but they are out of stock. I am not able to find that part number in any of the searches I do on the GM parts websites. If I have to replace the whole thermostat housing that is fine also as long as it comes with the valve.
Old Aug 22, 2006 | 06:05 PM
aminnich's Avatar
aminnich
Since the LT1/4 was used in vettes, camaros, etc,etc, you might find the local auto parts store has one.
Old Aug 23, 2006 | 12:42 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Hmmmm. According to GM Parts Direct's web site, the part numbers you seek have either changed to a new part number or are no longer available from GM.
http://www.gmpartsdirect.com/results.cfm
I would try your local auto parts counter.
Old Aug 23, 2006 | 01:33 PM
kalister1's Avatar
kalister1
Try 10070107 ( Valve Eng cool Air Bl) part of 10108667(Inlet water pump with thermostat housing and bleed screw)
Old Aug 23, 2006 | 03:06 PM
onedef92's Avatar
onedef92
GM Parts Direct calls 10108667 an Engine Coolant Pump Inlet. They stock it for $12.93 plus shipping.
Old Aug 23, 2006 | 04:25 PM
rickneworleansla
I believe 10070107 looks correct for the part I need.
Thanks to everyone!
To Coolent Bleed Valve Stripped
