Auto transmission gurus....
Old Sep 15, 2006 | 12:59 PM
silver86's Avatar
silver86
Default Auto transmission gurus....
Couple of symptons here before I take it to a shop (it should be noted that I'm a transmission idiot...) Car is an 86 auto
1. Sever lag (lack of power) from stop to about 1200-1500 rpm, then it seems to kick in gear. I am moving, just a definite lack of power to the wheels. It's ok on down shifts, and shifts well....
2. On the highway, at say 75 mph, when I left off the gas it acts as a manual would. Meaning, instead of coasting to a slower speed, the engine rpm's pull it down, almost like I popped it into a lower gear.
Any insight is greatly appreciated.
Old Sep 15, 2006 | 03:34 PM
toptechx6's Avatar
toptechx6
My gut feeling is you have a torque convertor problem but Pete will know for sure, he is THE MAN!
Old Sep 15, 2006 | 05:15 PM
Pete K's Avatar
Pete K
It does sound lock up related. Crawl under the car and look at the drivers side of the trans, towards the rear of the pan. 2 inches above the pan rail is a white, 4 prong plug. Unhook the connector and go for a test ride. If it clears up, it is lock up for sure. Then you can begin to diagnose the problem in the lock up curcuit.
Old Sep 15, 2006 | 09:13 PM
silver86's Avatar
silver86
I will certainly crawl up under there and check that, thanks.
To Auto transmission gurus....
