tune up question
Old Sep 21, 2006 | 11:57 AM
franks96ce's Avatar
franks96ce
Default tune up question
my 96 has 104,000 miles on it and i think its about time to do a tune up. so what are your suggestions and what brands. Ive had it for 1 1/2 years and its never been done.
Old Sep 21, 2006 | 12:56 PM
runner140*'s Avatar
runner140*
How far into the tune-up do you want to go? Plugs and new wires are a must. Change ALL fluids (brake, steering, coolant, oil, trans. and rear end. Also change all hoses and serpentine belt. Change your filters,(air, fuel, oil etc.). Clean your throttle body.
The above is for starters and should keep you busy for a while.
Good luck
Old Sep 21, 2006 | 01:13 PM
RRT vette's Avatar
RRT vette
Good luck
and also grease the zerks.
Old Sep 21, 2006 | 08:30 PM
Lone Ranger's Avatar
Lone Ranger
Taylor Spiro Pro on the wires. As for plugs, you will find as many opinions as there are plug brands. I use AC Rapidfire #14 and like them.
Old Sep 22, 2006 | 09:33 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't forget your O2 sensors and PCV valve, too. Too important, but often negletected tune-up items.
I'd go with either Denso or AC/Delco on the 02 sensors, doesn't really matter on the PCV valve. The AutoZone special at $1.99 will work just fine.
Also, don't forget the rear differential. Use the Mobil 1 Synthetic Gear Oil 75/90 weight and two bottles of the GM Rear Axle Additive (dealer only).
Old Sep 22, 2006 | 10:28 AM
RRT vette's Avatar
RRT vette
Ahh, two other maintence items as well.
To tune up question
