LT1 to LT4 conversion?
Old Sep 16, 2001 | 02:24 PM
IcemanZ06's Avatar
IcemanZ06
Default LT1 to LT4 conversion?
Has anyone had any experience with the LT1-LT4 conversion that is listed on http://www.paceparts.com?
"Our LT1 to LT4 conversion will bring the most out of your factory LT1 engine with bolt on parts. It includes LT4 cylinder heads complete with valves and springs, a beautiful red aluminum LT4 intake manifold, GM Performance Part's HOT cam kit which includes 1.6:1 ratio Bow Tie roller rockers, and all the necessary gaskets to complete the job. We also offer the correct Edelbrock/BBK throttle body assembly to bring the most out of this conversion. This kit is a proven 425+ horsepower increase ! - $2095.00"
is this for real? doesnt the LT4 use larger intake/exhaust valves plus higher compression pistons and would I be better off doing a conversion of this type by peicing it together myself?
Old Sep 16, 2001 | 02:40 PM
bogus's Avatar
bogus
Default Re: LT1 to LT4 conversion? (IcemanZ06)
I don't think the LT4 had more compression. Remember - the LT4 is RATED at only 30 hp more (most of us agree - it is more like 50 more than the LT1!).
There were a number of differences between the LT1 and LT4. The biggest being the cam and the heads. What the differences are, I really don't know.
If they are getting that kind of power, for that $$, it sounds like one helluva great deal! I may want to check that one out!!!
Old Sep 16, 2001 | 02:52 PM
RichS's Avatar
RichS
Default Re: LT1 to LT4 conversion? (bogus)
The LT1 had 10.4 the LT4 has 10.8 compression.
Old Sep 16, 2001 | 03:06 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Iceman,
I never compared the purchase to acutally buyuing the stuff seperatly. But I can tell you what i do know.
LT4-If you look around you can get them for 800-1000
LT4 Intake- $200 new from a dealer
LT4 Rockers-$150, they are always for sale on the forum or put up a wtb post
i got mine off the forum for 150
LT4-Don't know value
BBK Tbody-$300 New, 225 used from a forum guy or on ebay
Work it it out, it may be worht. I have always liked putting my own parts and combination together, it has always been cheaper, plus i pick the parts.
The LT4 has 2.00/1.55 valves and they are also hollow stem for reduced weight. THe LT4 runs 10.8:1 CR.
The only thing that pace has over the factory LT4 is the cam. But 425 seems to be pretty generous. I could be wrong.
If your car is an automatic, reconsider the cam, somehting like a ZZ4 cam would be better for the auto's opperating ranges.
Good Luck,
89'
[Modified by 89'Bowtie, 1:07 PM 9/16/2001]
Old Sep 16, 2001 | 03:12 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I looked at this kit long and hard before I did my car. It has many advantages for some people but for the diehard racer looking for max performance it has to many holes.
Old Sep 16, 2001 | 03:21 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: LT1 to LT4 conversion? (89'Bowtie)
Iceman,
The only thing that pace has over the factory LT4 is the cam. somehting like a ZZ4 cam would be better for the auto's opperating ranges.
Question about the valves. On the LT1 the standard valve sizes are 1.94"-intake/1.50"-exhaust. the LT4 uses 2.00"-intake/1.55"-exhaust.
Lets say I opted against the LT4 heads and ported/polished the LT1 heads (stage I). Would the 1.6RR still clear and also would the LT4 valves fit inside the head or are these dependent on the LT4 head type?
Also, what kind of increase could i expect from a ZZ4 cam? Keep in mind, my car is a daily driver, however I do not mind a little fun :D
[Modified by IcemanZ06, 1:22 PM 9/16/2001]
Old Sep 16, 2001 | 03:34 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
The stock LT1 heads flow about 210cfm. The Sotck LT4 Heads flow 240cfm.
YOu could port the LT1 heads to flow, but the LT4's are better by design. It is all in the design of the actual intack and exhaust runners that helps them to flow more, plus the runners are larger. The LT1 intake ports are 170cc and the LT4's are 195cc. The LT4 have more down the road potential for more porting. You would have to see if your local speed shop can get Lt4 flow figures out of the LT1 for cheaper than buying the heads.
Also, the valves, the LT1 heads would need larger seats to accomodate a larger valve. Without new seat and machinging it is not possible. For the money you are going to spend for bigger vavles in an LT1 heads and the porting sometimes it is cheaper do buy the whole head.
The ZZ4 actually make a little more HP and TQ below 4500rpm. After that the LT4 hot cam starts to come alive and makes more. You can see why.
ZZ4 Cam-208/221 0.474/0.510 @ 0.050
HOT Cam-218/228 0.525/0.525 @ 0.050
That why i say for a daily driver or an auto, a ZZ4 cam is a consideration, unless you race with a auto.
89'
Old Sep 16, 2001 | 03:42 PM
IcemanZ06's Avatar
IcemanZ06
:D :D
I have every intention of getting 12s out of my car and doing some autoX on the side here with the Clemson Sports Car Club on the weekends
Old Sep 16, 2001 | 03:49 PM
89'Bowtie's Avatar
89'Bowtie
St. Jude Donor '13
Ice,
Put it this way.
Higher RPM visits and opperating=LT4 Hot cam
Mid Range RPM opperation=ZZ4 spec style cam
Hight 12's shouldn't be that hard. You may consider a torque converter and 12's are 1/4 mile away.
89'
:flag
Old Sep 16, 2001 | 04:28 PM
No Go's Avatar
No Go
I believe the 425 HP that advertisers use comes from the engine being tested on a engine dyno/gross HP. Chevy High Performance did a build up of a LT1 converted to LT4 with HOT cam and came to this number as well.
Old Sep 16, 2001 | 04:48 PM
lcvette's Avatar
lcvette
ice,
i just finished some mods you may be interested in. for less then the lt4 upgrade, i opted for thes mods:
hotcam kit(cam, rockers, springs, shims, etc.. - $522
gaskets/ timing set/ misc. - $250
self ported LT1 heads/ Intake - 15 hours + $59 for SA porting kit
Meziere elec waterpump - $200
hooker ceramic long tube headers - $470 shipped
additional exhaust work - $50
labor - did myself took 3 weeks outside a 5 day a week job and 3 weekends for Everything including head porting
5 angle comp. valve job - $100
new Opti - $237
miscellaneous items - $100
total - $1988
Reading a 12.45@114mph on your time slip after mowing down a N2O stang and learning to all this work yourself.......PRICELESS!! :lol:
just an idea but i feel i got alot of goodies and performance for my $2k and it allowed me to add my pretty wheels and tires on top of it!! with a nice SLP exhaust system. also, i am still getting ready to add gears so perhaps an 11.9xx is in the future after some tuning!! :smash:
good luck,
chris
Old Sep 17, 2001 | 10:56 AM
Rick93Z07's Avatar
Rick93Z07
Default Re: LT1 to LT4 conversion? (lcvette)
"Built" versions of the LT1 and LT4 motor result in nearly the same output. "More Performance" and "Lingenfelter" offer nearly identical dyno tested LT1 and LT4 packages that use OEM heads and intakes for Emissions certification. The difference is a measily 10 HP, 425 HP LT1 vs 435 HP LT4. Plus, the LT4 requires intake manifold porting and the LT1 does not. Switching to LT4 heads and intake for 10 HP doesn't seem to make economic sense. Plus, the LT4 setup has a narrower, higher RPM powerband that can overstress the LT1 bottom end and result in the spitting of parts. The 425 HP LT1 produces peak HP below the stock LT1 rev limit.
Old Sep 17, 2001 | 12:03 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Default Re: LT1 to LT4 conversion? (Rick93Z07)
Does anyone on this forum have the Lingenfelter package installed? I've been thinking about it myself.
Old Sep 17, 2001 | 03:55 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: LT1 to LT4 conversion? (khornet)
Not sure about the LT1 performance numbers but a friend of mine had an LPE 383 L98 and it was killer fast. 1/4 in the mid/upper 11s N/A :D
Would be awesome to see the LT1 equivelent
Old Sep 17, 2001 | 04:03 PM
7xchampcar3's Avatar
7xchampcar3
Default Re: LT1 to LT4 conversion? (No Go)
I have that article if anyone needs it. I was pretty impressed by the results.
Old Sep 17, 2001 | 04:06 PM
khornet's Avatar
khornet
Default Re: LT1 to LT4 conversion? (7xchampcar3)
Please post!
Old Sep 17, 2001 | 06:46 PM
RichS's Avatar
RichS
A good machine shop can put 2.00/1.56 in the LT1 heads with the stock seats. There is enough of a seat there. But it needs larger seats installed for anything bigger.I used the stock LT1,ported with bigger valves in my 95 LT1 6 speed with the Hot cam. The best time was in my sig. If it was in Mack or JPs car it would have went 11's :D
[Modified by RichS, 5:47 PM 9/17/2001]
To LT1 to LT4 conversion?
Old Sep 18, 2001 | 11:13 AM
7xchampcar3
I can't post it but I can send it to someone that can :rolleyes:
[Modified by 7xchampcar3, 3:14 PM 9/18/2001]
Old Sep 18, 2001 | 12:59 PM
Chris@SD's Avatar
Chris@SD
Not on our flowbench they don't.
Actually, the smaller runner is exactly what makes the LT1 head better until you get into radical porting and cubic inches, and by radical, I am talking about over 300 CFM of flow!!! That does mean that you do have more potential down the road, but it is not useful potential unless you are going for an all out race motor with over 400 cubes.
Not true at all! The stock seat can and does accomodate a 2.02" intake valve with very little trouble. We seat them like this on a daily basis.
Old Sep 18, 2001 | 05:52 PM
BlondePebbles's Avatar
BlondePebbles
Pace's kit is great if you're going to do it yourself. You save some money. If you go someplace like MORE Performance, you get a similar LT4 kit, with a different cam, and all the experience they have for the installation, but it costs more.
From what I've seen, the LT4 kit puts out similar power to a ported LT1 heads kit with the LT4 hot cam. It all depends on what you want and what you're willing to spend! :seeya
