Horn Problem
Old Oct 25, 2006 | 07:48 PM
Jeff Begor's Avatar
Jeff Begor
Default Horn Problem
I have a 92 with what I call an anemic horn. Driver side works just fine which is a F note ( F-360 ) on the horn. Passenger side doesn't sound off at all which is labeled as an A note ( A-450 ). Swapped out the two and the F note works just fine on the other side and in turn the A note horn does not work on the driver side so of course it certainly appears to be a bad horn. Can anyone confirm that my 92 should be set up this way with the F and A note horns ? I ask because it appears someone may have swapped out the passenger side horn and if so is it the correct horn or should another note ( such as a C note ) have been used.. Thanks for your help... Jeff :
Old Oct 25, 2006 | 09:31 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
There is a screw on the horns that adjusts the volume. Try that first.
