Flow of a 91 L98
Flow of a 91 L98
The 48mm TB should flow 670cfm or so, and i am going to attempt to match up the rest of the intake. Maybe aiming for 800cfm with a 52mm TB.
Does anyone have flow numbers(cfm) for the stock plenum?
Ported Plenum?
Runners?
Heads?
Anything I'm forgetting?
Ported Plenum?
Runners?
Heads?
Re: Flow of a 91 L98 (MattJungels)
Check the 3rd Gen Camaro board, they have a good comparison there of those and aftermarket parts as well.
Again, there are some flow numbers at the http://www.thirdgen.org tech articles section.
Here are some flow numbers I got in an email. Remember, flow numbers are not gospel. A lot depends on the bench, who's using it, the weather, and if it's been calibrated.
Hey, finally a question to which I have the answer!! I compiled the data
below from two sources (GM High Tech Performance magazine and TPIS
Insider Hints reference).
From GM High Tech Performance July 2000 issue:
Runners:
Stock: 203.17 cfm
Accel: 242.02 cfm
Extrude/Accel: 275.83 cfm
Super Ram: 289.18 cfm
Stock Intake w/ the Following Runners:
Stock: 198.72 cfm
Accel: 213.52 cfm
Extrude/Accel: 217.11 cfm
Super Ram: 220.67 cfm
Accel Intake w/ the Following Runners:
Stock: 215.83 cfm
Accel: 232.53 cfm
Extrude/Accel: 243.21 cfm
Super Ram: 240.24 cfm
Stock Intake w/ 3/8" Radiused Inlet: 222.45 cfm
Accel Intake w/ 3/8" Radiused Inlet: 251.51 cfm
Extrude Honed Accel Intake w/ " ": 275.83 cfm
Extrude Honed Accel Intake w/ Accel Runners: 266.94 cfm
From TPIS Insider Hints:
(note: TPIS' flow data on same components varies by approximately -15cfm
versus GMHTP data)
Stock throttle body: 668 cfm
" with TPIS airfoil: 709 cfm
Stock MAF: 529 cfm
Screens out: 711 cfm
Fins removed: 750 cfm
Stock intake base w/ stock runners: 181 cfm (vs. 198.72 cfm in GMHTP)
Stock intake base w/ cast large runners: 193 cfm (vs. 213.52 cfm " ")
Stock intake, stock runners, ported plenum (presumably stock 48mm TB:
183 cfm
Stock intake, stock runners, ported plenum, TPIS airfoil: 187 cfm
Ported intake, stock runners, ported plenum, TPIS airfoil: 193 cfm
Ported intake, siamesed runners, ported plenum, TPIS airfoil: 203 cfm
Runners:
Stock: 203.17 cfm
Accel: 242.02 cfm
Stock: 198.72 cfm
Accel: 213.52 cfm
Stock: 215.83 cfm
Accel: 232.53 cfm
versus GMHTP data)
Stock MAF: 529 cfm
183 cfm
