Will a 4+3 flywheel fit a 1-piece rear main seal block???
Location: Looks like I picked the wrong week to stop sniffin glue Orlando
The Richmond 6-speed conversion is going to be expensive enough as it is, so im looking to cut the cost of an aluminum flywheel and Centerforce clutch. If I have to go back and replace them in a year or so that’s fine, but I just want to get the conversion done. I’m looking to use a new replacement flywheel, and a standard clutch. :cheers:
Re: Will a 4+3 flywheel fit a 1-piece rear main seal block??? (weekendwrench)
Yep that helps. I wasn’t sure of when Chevy switched over to the one-piece rear main seal, but I wonder if there were any differences in the block or parts used when the whole 4+3 to ZF change went down at Chevy :chevy
Re: Will a 4+3 flywheel fit a 1-piece rear main seal block??? (IBEAM700)
Well, during my search for flywheels im coming across all types. Id like to keep my stock mini starter after the conversion. Does the 1990 Corvette Auto. Have a 168-tooth flexplate? Does anyone know how many teeth the 84-88 4+3 had? :chevy
1 Post
Cruise-In II Veteran
I believe that all C4's had a 153 tooth flywheel or flexplate. The 4+3 cars were 153 tooth too and the one-piece seal version arrived with the 86 MY. The 4+3 flywheel was a factory light-weight flywheel only used on the 4+3 Vette and some V-8 F-body applications. It can be replaced by a std weight flywheel if so desired. Here some GM P/N's and prices if you're interested:
Light-weight Flywheel
One-piece rear main seal
P/N 14088646
$201.30
Std-weight Flywheel
P/N 14088650
$178.86
Two-piece rear main seal
P/N 14085720
$159.33
Std-weight Flywheel
P/N 366860
$173.58
P/N 14088646
$201.30
Std-weight Flywheel
P/N 14088650
$178.86
P/N 14085720
$159.33
Std-weight Flywheel
P/N 366860
$173.58
Re: Will a 4+3 flywheel fit a 1-piece rear main seal block??? (18carfan)
Thanx for the info carfan. Looks to be worth the extra 20$ for the light weight unit. :chevy
