Traction Control: ASR, can you modify the programming?
Old Feb 4, 2007 | 08:22 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Traction Control: ASR, can you modify the programming?
I noticed the traction control got better and better as the C5 came abou then the C6. Is there any way to get into the traction control on a C4 and modify it for better traction?
Old Feb 4, 2007 | 08:57 PM
STL94LT1's Avatar
STL94LT1
As far as I know, not through programming.
Old Feb 5, 2007 | 12:31 AM
steve40th's Avatar
steve40th
Darn. We need to go and kidnap a programmer from GM that knows how to unlock that menacing thing called ASR. The newest cars are pretty sophisticated in their ASR/Traction controls.
Old Feb 5, 2007 | 07:34 AM
Casethecorvetteman's Avatar
Casethecorvetteman
You can adjust how much spark retard it can apply.
Old Feb 5, 2007 | 10:40 AM
steve40th's Avatar
steve40th
I use CATS Tuner, Novice here, or lets say I have it. Where is it and have you ever played with it?
I know eventually it throws on the brakes and pushes the throttle back. Would adjusting the spark retard reduce these other effects?
Old Feb 5, 2007 | 11:20 AM
STL94LT1's Avatar
STL94LT1
I overlooked this one in my $EE file, "Traction Control Spark Retard vs RPM".
Old Feb 5, 2007 | 12:47 PM
Casethecorvetteman
Yeah i dont know if its in the earlier def files, but reducing the amount of retard will reduce the amount of power it will cut down when it comes on.
Old Feb 7, 2007 | 12:07 AM
96GS#007's Avatar
96GS#007
Lot more to it in the newer ones than just the programming. Better brake controller, faster processor, more sensors, etc
Old Feb 7, 2007 | 12:46 AM
steve40th's Avatar
steve40th
Thanks guys again. I guess its worth a try? Anyone want to try? Alvin!!!!
Old Feb 7, 2007 | 06:43 AM
Casethecorvetteman
Mate if you had a 94/95 id change them for ya!! I honestly wouldnt like to guess at what sort of changes you would need to make to get it the way youll be happy with it, and again, if you had a 94/95 it would probably be alot easier to experiment with it. It might take you a few goes to get what you want from it, but if you have the ability to burn your own chips, get to and and experiment!!
Old Feb 7, 2007 | 10:46 AM
steve40th's Avatar
steve40th
I have the software, burner etc etc. I may look into this further, cant hurt. The only thing that the ASR does thats a pain is the throttle and brakes application for severe traction loss. Its like throwing an anchor out of the Vette.
Old Feb 7, 2007 | 11:23 AM
steve40th's Avatar
steve40th
My DA2 1993 Y body file doesnt have anything that says traction control. Unless I am overlooking something.
Old Feb 10, 2007 | 10:06 AM
Casethecorvetteman
Yeah i just had a look and cant see it either....
http://www.tunercat.com/tnr_desc/do_tc.html
http://www.tunercat.com/pdfs/ecm_$da3.pdf
I checked the ZR1 files as well and they dont seem to have anything there to adjust it either. Must be only on the $EE and later.
Old Feb 10, 2007 | 10:52 AM
steve40th's Avatar
steve40th
I guess my right foot and sticky tires will be my traction control.
Old Feb 12, 2007 | 11:45 PM
Mo_Bandy's Avatar
Mo_Bandy
I'm sure it is in the older ECM's on my 96 you can adjust how much timing the ASR pulls...
i set my back about 10-15 degrees across the board as with my supercharger I was like a deer n the headlights if i punched it with the ASR on.
It worked good... on the 96 you can also have it disabled but it causes the SYS to flash.
i realize you are dealing with a different ECM but I'm sure you should be able to to do similar things with tunercat...
hope this helps,
MO
Old Feb 12, 2007 | 11:56 PM
steve40th's Avatar
steve40th
hope this helps,
MO
I looked through Tuner Cat and didnt see anything obvious for this. What was the 96 ASR function called within your programer?
Old Feb 13, 2007 | 01:12 AM
Mo_Bandy's Avatar
Mo_Bandy
Hi Steve,
It is listed as "Traction Control Retard" it is under the ignition tab on LT1 edit...
Mo
To Traction Control: ASR, can you modify the programming?
Old Feb 13, 2007 | 01:22 AM
MaxLean's Avatar
MaxLean
My '94 has that parameter as well. In the switch constants, there is a check box for traction control. Even with this set to disabled, the asr still works, it just doesn't retard the timing during an asr event. In other words, it just works the throttle relaxer and brakes harder until it gets the desired results.
Scott
Old Feb 13, 2007 | 11:17 AM
JA94vette's Avatar
JA94vette
I wish there was a way to do away with the kick in the foot and just cut back the power via retarding the timing. If you unplug the ASR box under the hood and remove the ASR diagnostic code would you have the situation where you don't have the pedal kick but the timing is still retarted.
Old Feb 13, 2007 | 11:24 AM
Casethecorvetteman
Connect the throttle cable straight to the throttle body. It cant close the throttle blades then. I dont know if it would set a DTC but it shouldnt if its still plugged in.
