Question: LT1 Exhaust Manifold "Donut" Seals
Possibly 1996 LT1/ LT4 only, apparently not used on 92 through 95 LT1. Anybody know where these could be obtained? OEM part number is 15713154 and is not available for ordering through dealer parts anymore.
Thanks, Greg
Thanks, Greg
Hmmm, I've never heard of a donut gasket on an LTx exhaust manifold.
I work for GM and we still use a a donut gasket on the LU3 4.3 engines. I'll bring one home and see if it will work on my LT1 manifols that I have laying in the garage.
Manifold part number is different for 96 and incorporates the composite material donut seal. Looks like the catalytic converter flange on 95 and earlier does not require the "donut" and fits a radiused boss on manifold which 96 does not have. Any assistance on this one greatly appreciated!
Muffler shop..........
Easy fix! Head to your muffler shop, Speedy, Midas, tell them what you need and they can order it if they don't have it in stock.
HTH LT1Vette
HTH LT1Vette
Cheaper at the muffler shop...........
Greg...It'll be a lot cheaper at the muffler shop and the same quality if it's made by Walker. (they supply most of GM's exhaust), and it probably won't be a special order if it's a busy shop..............
Greg, I know I am bumping an 8 year old thread, but do you have any tips for getting the exhaust manifolds back on?
My passenger side manifold on my 94' was cracked so I purchased a NOS exhaust manifold from Rim Rock Chevrolet which requires the doughnut seal between the manifold and the down pipe like the 96's have. I purchased the GM Dough Nut gasket #15170285 and I cannot for the life of me get the manifold to line up properly with the head to get the manifold bolts started. I even went to advance to purchase the Fel-Pro variant part #61258 and it is identical to the GM seal.
Right now I have the manifold and seal in the freezer to leave over night and I'll try again tomorrow. It is almost as if the seal is too thick and the manifold is sitting up about a 1/16" too high.
Any tips or advice would be awesome.
Patrick
Patrick
Patrick
Patrick
Manifold needs installed to cylinder head "BEFORE" you install anything else. You can't connect convertor to exhaust and then install the manifold to engine.
I don't really catch your problem and don't see how the donut is related.
If you have a problem with the bolts to cylinder head "end to end" then you use a spreader but that's generally only required when replacing older/used manifolds. Maybe required new? I wouldn't think so.
You mention MANIFOLD TO CYLINDER HEAD. Is that correct? If that's correct just get your self a KD tool - manifold spreader and you'll be all set. They're generally only required when reinstalling older manifolds but I expect they would get the job don on new also.
I don't really catch your problem and don't see how the donut is related. I would think a new manifold wouldn't require a spreader BUT... happens.
92'-95' Cars had a boss cast into the manifold that didn't require a doughnut. The newer replacement manifolds and the manifolds that come on 1996 cars require a doughnut between the down pipe and the manifold itself. You first have to push the seal into the collector of the manifold before you install it on the engine. The seal is so thick that when I set the manifold in place it interferes with the down pipe and I can't even get the bolts started into the cylinder head because the manifold is about 1/16" higher than it should be. Hope that makes sense.
With the old original 94' manifolds I am able to install them no problem with the cats still in place. Guess I will need to remove the cat first which I never had to do before. Then I will more than likely have trouble getting the cat lined up with the mounting bracket.
Hard to explain without a picture I guess.
If so, it sounds like a mismatch of parts; I would really try to get a manifold with the stock boss cast into it; either that, or have a muffler shop weld a new flange on the front of the catalytic converter that will accommodate the donut ...and don't sic the fed's on me for suggesting a "modification" to a functioning catalytic converter.
There's nothing unique with the donut/seal to the down pipe or convertor whichever. It's been used since maybe '95 on all GM's.
If the donut/seal is correct the sleeve needs to be inserted until the "flat of the donut" contacts the manifold. It's meant to be a force fit.
***See if your local AP store might have a FelPro 61012 - it seems that we used that when the pricing got ridiculous on the GM seal. That's a BEST I RECALL thing -
Don't talk like that on a open forum good way to loose your job
Yes it is, and no it wasn't. I actually didn't have to remove the cat entirely, I just loosened up all the mounting bolts and it dropped a 1/2" or so. Bolted the manifold to the cylinder head and then tightened the cat back up to it. Not sure why I didn't think of doing that before. I was always able to install the old style manifold without unbolting the cat from its mounting bracket. Started right up, no leaks, sounds much better.
I appreciate the tip WVZR-1 . The exhaust system is finally where I want it to be (Except for Corsas ).
