distributor timing - spark plug position
I think first I need to determine exactly which spark plug wire goes where on the distributor first. Can anyone help me in that regard, perhaps a diagram of some sort. Then from there I can find the right timing by rotating the distributor little by little until the engine fires up...it can't be that off I believe. But if I am, then what? Is there a tech article that you guys can point me too. I have a 91 C4 L98.
After it's sorted out and everything is connected, disconnect the EST wire and tighten the dist hold down bolt so that the dist will still turn with a little effort. Start the engine and use a timing light and turn the dist to 6* BTDC. Tighten the bolt and recheck. Stop the engine and reconnect the EST. Disconnect the battery to clear the code and start the engine again. The timing will be around 22-24* or 12 o'clock on the balancer.
Thanks a bunch Sam, it does make sense. i'll give it a shot tomorrow as it's too dark out now.
There are four strokes - intake, compression, power, and exhaust
From top dead center (TDC), the intake stroke is initiated by the piston moving down to bottom dead center. During this period, the intake valve closes (the exhaust valve has already closed long ago).
The piston then starts back toward TDC, compressing the mixture drawn in while the intake valve was open (compression stroke).
When the piston gets to TDC, the spark ignites (actually, the spark fires a few degrees BEFORE TDC), and the rapidly expanding gas pushes the piston back to BDC.
The inertia gained from that explosion causes the piston to continue past BDC, and the open exhaust valve allows the spent gases to escape through the exhaust manifold. Then, of course, the piston is back to TDC, and the intake stroke begins again ...
So, the reason you need to have your finger in the hole is so you know if the piston is on a compression stroke or an exhaust stroke. If you make a mistake at this point, the engine timing will be off by 180 degrees, and the rotor will be pointing exactly opposite of where you really want it!
Once you've given this some thought, you'll understand it better. This will be even more apparent if you remove the distributor cap, and observe the compression and exhaust stroke with respect to where the rotor is pointed.
Good Luck!
Steven
And I'm not sure as to whether I should adjust the oil shaft....will this throw everything off...or should I simply be able to remove the distrib. and drop it in with the rotor pointing at 1 once I get TDC.
Once you get the engine close to the #1 TDC position you should be able to roll the engine slightly by hand to align the timing marks up perfectly on 0 degrees. Only then can you insert the distributor in the engine with the rotor pointing roughly towards the drivers tire and as you drop it in the rotor will engage the drive gear on the camshaft and will roll to its final and correct spot pointing to the 1:00 oclock position as earlier described. This is really nit picky but it must be done right to work right. I hope this helps a little at least.
I think it's at 6 btdc, though I could be wrong. Right now the line on the balancer is set at 6 below the 0 mark on the balancer. I think this is BTDC. My question is should it be set at 6 above the 0 on the balancer. Again, I seemed to of lost that off the line power...and most of the power seems to come in at the high RPM now. I use to be able to launch and lose traction due to all the power, but now the power just isn't there at the low end. Any ideas?
