check gauges light
Old Mar 18, 2007 | 11:02 AM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
Default check gauges light
I have a '91 L98. My check gauges light came on yesterday. The only thing that appeared to be off was the oil temp gauge. The needle barely moved from minimum. I checked the oil. It was quite warm and full. After a couple hours sitting, I drove home and the check gauges light was off. Anyone have that happen? On another note, every once in a while, whether I am moving or sitting in park, my ABS Active light comes on for about a second. What's up with that? I have never been touching the brakes any time that light comes on.
Old Mar 18, 2007 | 11:34 AM
C4Techie's Avatar
C4Techie
I am not familiar with a "Check Gauges" light. Are you sure it didn't say "Check Engine"? Or "Service Engine Soon"? If so, the ECM received a sensor reading that was out of line with all the other sensor readings. Pull your trouble codes to see which circuit sent the erroneous info, then trouble shoot to find out why.
Old Mar 18, 2007 | 01:08 PM
carlton_fritz
It's the red check gauges light that is with the speedo, on the right side.
Old Mar 18, 2007 | 01:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The check gauges light comes on for many different reasons. The most obvious is oil temp, pressure, coolant temp and volts, but also for gasoline. If you go to reserve and keep going, the check gauges light will come on to remind you to get gas.
Old Mar 18, 2007 | 03:14 PM
carlton_fritz
Oil pressure is good. Coolant temp was in normal range. Voltage was where it should be. I have an almost full tank. That leaves the oil temp gauge. Thanks. I will get it checked.
To check gauges light
