My 90 has run warm from almost day one. It has 30K miles on it and I relpaced the thermostat with a 180. I put in a Hypertech chip (Street) and I thought it would turn on the fans sooner. The primary fan comes on fairly early, but the secondary hardly ever comes on. I read the service manual and there is several criteria that has to take place before the ECM says turn on. The car doesn't run warm while driving, it is more when it is at an extended idle. I just purchased an automatic kit for the secondary fan. It consist of a thermal switch and a harness. I am assuming that the thermal switch goes somewhere in the block and the harnes goes to the negative leg of the fan relay. Again I am just guessing but I believe it will override the ECM and turn it on at a predetermined temp. My real question is has anyone ever used that additive that you mix in with your water? It is suppose to tranfer heat better. Is it safe for the alum parts?
Not to ask a dumb question, but have you ever changed the antifreeze? How about removing the shroud that covers the radiator? C4 corvettes draw air from under the car, and can pickup trash , leafs, and plastic bags that lodge around the radiator. Do a search, there are many threads on this subject.
You don't mention when the chip turns your fans on and off...with a 180* t-stat it should be around 190 and 182*....
I run a 160* t-stat and my fans are set to go on at 198 and off at 192*...these settings are from a previuos t-stat and I've never gotten around to changing them...in traffic or at extended idle my fans come on and drive the temp down to 196* ...that is as hot as it gets...
I also run one gallon of anti freeze, 2 bottles of water wetter and the rest distilled water...I may cut back to 1/2 gallon of anti freeze since down here freezing is not an issue...plain old distilled water is the best cooling agent by far but I want a little anti freeze in the system for the lubricating properties...
From: One day you're a Comet...the next day you're dust... Arkansas
The sensor/switch replaces the sensor between plugs 1 and 3 on the drivers side. You can wire it a couple of different ways. I wired my 1989 to turn the aux fan on early. My aux fan comes on at 200* and off at 185*. I left my main fan alone it comes on at 226*. This will most likely solve your problem in conjunction with the 180* stat. I believe you can download instrutions from Mid America's site.
BTW I never use water wetter but some swear by it.
I don't think those analog gauges are very accurate.
Pay close attention to the temperature on a 90. I have a 90 and it overheated to the point of a blown head gasket.
Check for cold spots on the radiator (blocked by deposits) also make sure there is no air in the closed system. Also avoid prolonged stand still
idle. Have you checked the relays on the drivers side of the radiator housing they have failed on mine.
Randy[/QUOTE]
Randy is correct the C4 is a known street hoover. Do an R&R on the rad and do a good cleaning. I bet your dealing with sediment issues as well as restriction. Another rare possiblity is extreme impellar wear on the water pump. But that is a long shot.
Something to check even if the radiator looks free of debris is the spaces within the fins. My 90 was a Florida car in its early life and when I got it in 2005 it would overheat very easily. I cleared the obvious debris but it still ran hot. Then I pulled the radiator and found that the bottom 1/3 was clogged with sand. A garden hose backwash helped but alot of the grains were stuck. I ended up putting it in a bathtub full of very hot water and when the aluminum expanded the majority of the sand dropped out. It worked well but the wife was a bit upset.
High pressure hose works good if the bathtub is too dirty to put your parts in
Spray it slowly from teh backside, over and over and over, youd be surprised how "clean" its not. Hold it up and see how much light you can see through it to judge progress....Then take a shop vac and slowly go over the face (front) of the radiator, that will get sand too. Do NOT press hard withthe vac, youll flatten the fins.
Using a small white bristled scrub brush (steal it from the kitchen ) on the front of the condenser is perfect for cleaning the fins out too, start at the top and firmly but gently run the brush from top top bottom. Then shop vac it out too, clean as a whistle. Condenser is important, if air cant get through there its not going to get much air to the radiator.
