A.I.R. pump 2nd thread...
Old May 27, 2007 | 10:14 PM
N.C. Kid's Avatar
N.C. Kid
Default A.I.R. pump 2nd thread...
Since my first one got deleted. I will repost my quiestion with I hope a truthful answer. From the pump there is this little hose that I suppose goes down to the cats? I cant see where it goes fully. Can I chop that off or does it go into something else? With the eliminator kit, will the stock "wishbone" still be attached to hold up the alternator? Thanks.
Old May 27, 2007 | 11:50 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
When you delete air, you delete and plug all lines.
the bracket from the alt to the header bolt will need to be adjusted/modified to fit... do not leave it off...
Old May 28, 2007 | 12:23 AM
N.C. Kid's Avatar
N.C. Kid
What do you mean modified? and how do I plug the lines? How many are there? Thanks.
Old May 28, 2007 | 06:17 AM
MR NICE's Avatar
MR NICE
Just rip the air crap off nothing to hurt.
Old May 28, 2007 | 06:28 AM
Puna's Avatar
Puna
On my '89 the tube (metal) rab down to the cat. As per Agent 86's excellent suggestion I plan to use the stock "y" pipe, put the 02 sensor in the drivers collector, and have the cat tube hole welded closed. Hope this helps. Also on mime that metal tube is bolted to the stock exhaust manifold.
Old May 28, 2007 | 12:11 PM
LouisvilleLT4's Avatar
LouisvilleLT4
That sucks that threads get outright deleted instead of just locked. Along with all the arguing there was some good information in there that is lost now unless you happened to save it.
Old May 28, 2007 | 01:25 PM
RRT vette's Avatar
RRT vette
Originally Posted by RRT vette
The A.I.R system is primarily used to inject oxygen into the main cat on start up. At start up, air is pumped into the exhaust manifolds and then changed to the cat after warm up. This helps clean up the emissions after start up. This system is not much use after the engine is at normal operating temps. Many members delete this system with a eliminator bracket or if they have headers with the A.I.R. pipe deletes.
Originally Posted by SunCr
Air is directed to the headers on startup to help light off the O2 and the oxygen in the exhaust stream also helps to warm up the CAT. Once in closed loop, it's redirected to the CAT to help oxidize NOX and HC's. Eliminate it and you may want to switch to a heated O2 (you'll need an ignition feed) and to comply with emissions, it'll need a more modern CAT.
An air system that continues to flow to the Headers after Closed Loop will be read (by the O2) as a lean condition and the ECM responds by delivering too much fuel; ie, it'll run rich. Broken header check valves will suck air into the exhaust stream and result in the same condition. An air system that doesn't divert overboard when you let off the gas (no flow to the CAT or Headers) will cause backfiring. Troubleshoot a rich condition by clamping off the hoses to the headers or simply disconnect a hose and see if there's air flowing through it. Check Valves can be removed and tested by making sure that air only flows through them in the direction of the headers (though if one is broken, it's pretty obvious just by looking inside of it). To see if it will divert, ground the diagnostic link or disconnect the TPS to set a trouble code and then listen or feel for air below the right side of the water pump at the discharge tube.
If you are running no cat, then the air pipe going to the cat has no use. It can be cut off.
Old May 28, 2007 | 09:17 PM
N.C. Kid's Avatar
N.C. Kid
Yea, but Id prefer not to get a big argument going again so I am going to keep it strictly to quiestions that are imiportant here if I need any help. I dont want to start trouble and end up getting booted off for some petty personal attacks or something stupid.
RRT, from what you just posted from my understanding is that by keeping the air pump on my set up now, it is causing my car to run rich? What happens if my car is running rich? What are the problems that this causes? Thanks.
Old May 28, 2007 | 09:24 PM
Aardwolf's Avatar
Aardwolf
He called the mods in by post #13.
Old May 28, 2007 | 09:33 PM
MR NICE's Avatar
MR NICE
At $3.50 to $4.00 a gal. your wallet get's lighter faster, you could foul plugs,contaminate oil,wash cylinder walls of oil and **** off tree huggers.
Old May 29, 2007 | 09:50 AM
N.C. Kid's Avatar
N.C. Kid
I was pretty nice last time but I really dont care. Its my car. Alot of people on here do it. I looked up the price of high flows last night and I refuse to pay that much. If someone wants me to get one so bad, then they can buy it for me.
Old May 29, 2007 | 10:01 AM
Wheelman's Avatar
Wheelman
Hi Flow What? A high flow cat is $60 on ebay...
Old May 29, 2007 | 10:08 AM
N.C. Kid's Avatar
N.C. Kid
Thats expensive for something that has no importance to me right now. When I can afford it---"when I am thru modding" then I will get one. I am taking donations of 60 dollars for a cat.
Old May 29, 2007 | 10:16 AM
mseven's Avatar
mseven
Line on pass. side should go to the cat, you will have to cut it/or remove.
Wishbone will be gone, kit comes with new bracket, bolts/hardware for install and should accept a stock belt. You can either put caps(standard pipe thread) on the exhaust inlets or you can just remove the lines going to that valve and leave the valve. The kits come with instructions (to some degree) that are pretty easy to follow.
My question is unless you want to work on it more easily why aren't you just getting another re-man pump (may be cheaper as kits are aroung 190.00) and calling it a day?
Old May 29, 2007 | 10:18 AM
N.C. Kid's Avatar
N.C. Kid
kit is 120 for polished one. If it makes it easier to work on, then YEA I want it.
Old May 29, 2007 | 10:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
I reported your thread just for the hell of it.
Old May 29, 2007 | 10:36 AM
N.C. Kid's Avatar
N.C. Kid
To A.I.R. pump 2nd thread...
Old May 29, 2007 | 10:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old May 29, 2007 | 10:58 AM
mseven's Avatar
mseven
thats better than when I bough mine
so.....there's some cheese eaters out there????
Old May 29, 2007 | 11:44 AM
CFI-EFI's Avatar
CFI-EFI
I bought a reman pump from Checker Auto Parts for $27.95, exchange. A pump and a $60.00 cat are cheaper than the eliminator. Wait until you have kids, (if the neighbors will let you) and they can't breathe because of what you did to your air. Don't worry about what "plenty of guys" have done. Clean air starts with YOU!
RACE ON!!!
