Another LS1 swap thread (pics)
Old 08-30-2007, 02:50 PM
  #101
Rainy99
Rainy99's Avatar
Awesome work Jeff! That motor kinda sounds familiar... lump lump lump!
Old 08-30-2007, 03:28 PM
  #102
pr0zac
pr0zac's Avatar
would you be able to use a truck pan and accessories on with this swap? you used an fbody pan and vette acc's correct?? how much room did that leave you moving the motor ahead?
Old 08-30-2007, 04:53 PM
  #103
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Beautiful
Old 08-30-2007, 05:10 PM
  #104
Jeffvette
Jeffvette's Avatar
Location: No more yankee my wankee, the Donger is tired!
Used F-bpdy pan and Vette Accesories. Not sure about the truck pan as it never entered my mind. If you go to much further forward you run into the cross brace. You won't have any room to chnage a belt. I can still get in and change the crank pulley. The way I did it does not involve any new holes in the C-beam.
Old 08-30-2007, 06:26 PM
  #105
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nicely done!
I like the valvecovers and coil setup.
Much better than the factory covers.
Old 08-30-2007, 06:42 PM
  #106
pr0zac
pr0zac's Avatar
cool.. thanks for the info.
Old 08-30-2007, 09:39 PM
  #107
1bdvet
1bdvet's Avatar
Received 4,498 Likes on 3,585 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
NICE JOB
Old 09-16-2007, 08:30 PM
  #108
DrEvil11417
DrEvil11417's Avatar
looks great!
how come you moved it forward? and how did you make up that fuel system? looks sick!
Old 09-16-2007, 09:11 PM
  #109
vette punk
vette punk's Avatar
Default Lsx/c4
Old 09-16-2007, 10:18 PM
  #110
Demonic85
Demonic85's Avatar
Wow nice
Old 09-16-2007, 11:06 PM
  #111
Jeffvette
Jeffvette's Avatar
Originally Posted by DrEvil11417
looks great!
Moved forward so I wouldn't have to worry about transmission placement.
Fuel system was tied into the exitsing fuel lines coming downn the passenger side of the frame. It uses a custom fuel filter housing and then is run up with stainless braided lines and utilizes a fast fuel rail system then goes into a aeromotive regulator then to the return line.
Old 09-16-2007, 11:54 PM
  #112
kpforce1
kpforce1's Avatar
That is sharp Jeff!! I'm sure plenty of people will get used to seeing the back of your car... and that website. :lmao:
Old 10-04-2007, 06:45 PM
  #113
ls1dave
ls1dave's Avatar
Jeff,
Did you make your own adapter plates for the motor mounts or did you purchase a set?? If you did purchase them, which company did you buy them from. Nice job on the convert.
Old 10-05-2007, 10:01 AM
  #114
0Speed Hound
Former Vendor
Speed Hound's Avatar
The ones we designed for Corvette Fever's project C4orce will be ready for sale on Monday. I took them to the coaters just yesterday to get them epoxy coated. We designed them to work with the L98 cars without making any modifications to the frame. Technically they should also work for LT cars, but I have not tried so I can not say for certain they do. www.speedhound.com is my website. I don't have the page up with the motor plates yet. I should have the whole site redone with in the next week or two I hope. Feel free to contact me if you need any more info.
When positioning the motor in these cars you'll need to not only take into account getting the motor into the car but also how the transmission will sit since there is no transmission x member to move around. If you're running a manual transmission, you'll need the stick to come through in about the same location as stock if you intend to also use the factory center console.
The other thing to know is that Melrose makes headers for a C4 running an LSx motor. They were designed based on using the motor plates we designed for C4orce. So exhaust is also a consideration even if you're planning to use factory manifolds. The headers are available from any Melrose dealer such as Jeff or myself.
Everything will fit no problem. You just have to know there are a couple of close places that you'll need to watch out for so you can plan accordingly.
Oh yeah, if you do a search in this forum for LS1 you'll find another very recent thread about doing this swap. You can see C4orce in that thread. The Melrose headers are on the engine in the pictures too.
Old 10-15-2007, 09:16 AM
  #115
ls1dave
ls1dave's Avatar
thanks speed hound.
Old 10-15-2007, 05:26 PM
  #116
Jeffvette
Jeffvette's Avatar
Originally Posted by ls1dave
Jeff,
Custom set to push the motor a little further forward. Didn't have to cut new holes for the C-Beam.
Old 03-27-2010, 01:45 PM
  #117
mattwalker87
mattwalker87's Avatar
what rad. did you end up using for this car? any more pics of how you tied into the orig. fuel lines-if you did.
thanks.
Old 02-27-2013, 02:04 PM
  #118
IAMC4CRAZY1984
IAMC4CRAZY1984's Avatar
Default putting ls headers in a c4
Hi jeff,
Thought i'd ask a highly respected veteran this question. I would greatly appreciate your oppinion.
Can you or should you put the ls motor in a 1985 vette before or after the Melrose headers GO IN. The issue here is, I don't have the funds readily available for the headers but if i put the motor in now I can get other things completed. Please advise. Im chompin at the bit here!! ha ha
Old 02-28-2013, 06:11 AM
  #119
DHobbs
DHobbs's Avatar
Sweet swap and sweet ride. I am utterly jealous.
Quick Reply: Another LS1 swap thread (pics)
