Header install problems (Hooker 2151 on LT1)
Old Jun 1, 2007 | 04:01 PM
carriker's Avatar
carriker
Default Header install problems (Hooker 2151 on LT1)
I'm installing Hooker 2151 on my 1995 corvette.
First major problem.
The passenger side header is resting on the motor mount, enough so that the header is up too high so most of the header bolts will not go in. Does the motor mount need to be cut a little, or does the header need to be dented a little?
I will likely have more problems, as I haven't even started to put the driver's side in, so more to come. Thanks for the help with my initial speedbump.
-Matt
Old Jun 1, 2007 | 04:04 PM
STL94LT1's Avatar
STL94LT1
Is it hitting the actual motor mount?, or just the motor mount's bolt?
Old Jun 1, 2007 | 04:20 PM
fredk's Avatar
fredk
With Exotic Muscle you remove the mounting bolt and put it in the other way around on the drivers side.
Fred
Old Jun 1, 2007 | 05:15 PM
_twisted_'s Avatar
_twisted_
try jacking the motor up from under the pan - you might have a shot mount - if the header fit with the motor jacked lower it slow and see what is going on.
Old Jun 1, 2007 | 07:28 PM
carriker's Avatar
carriker
It seems to be hitting the motor mount. It has some sort of insulation around it. I wil try to take that off to get a better look at the motor mount.
To Header install problems (Hooker 2151 on LT1)
