rattling calipers
Old Jun 1, 2007 | 04:24 PM
formerfoxbody's Avatar
formerfoxbody
Default rattling calipers
I have a 1988 a4 coupe that I recently installed cross drilled rotors, new pads and ss braided lines. Everything works well except now the calipers on the front rattle like crazy unless I'm applying the brakes. I also hear the calipers engage when applying the brakes. I've seen in some cases o-rings on caliper retention bolts to eliminate noise, do vettes have something similar? I didn't notice anything like that but maybe with age they became dry and came off. Any ideas would be appreciated.
Old Jun 1, 2007 | 05:46 PM
Aardwolf's Avatar
Aardwolf
Did you put these on?
http://www.vbandp.com/detail.aspx?ID=705
Old Jun 1, 2007 | 05:48 PM
TOMS93's Avatar
TOMS93
Originally Posted by Aardwolf
That should fix it.
Old Jun 1, 2007 | 06:13 PM
Aardwolf's Avatar
Aardwolf
There is a pin on the bottem of the caliper, if that is worn there could be a problem to. The pin is held in with a C-clip.
Old Jun 1, 2007 | 06:16 PM
N.C Punk's Avatar
N.C Punk
Im imitating N.C. Kid
Old Jun 1, 2007 | 06:27 PM
Repzard's Avatar
Repzard
So true
Old Jun 1, 2007 | 06:30 PM
Aardwolf's Avatar
Aardwolf
No, your his alter ego.. it's time to take your meds!
Old Jun 1, 2007 | 06:52 PM
formerfoxbody
Didn't know those existed, didn't see any come off. Who knows if they were there? Were they a factory item or aftermarket, where do they go and are they available from auto parts stores?
Old Jun 1, 2007 | 07:00 PM
N.C Punk's Avatar
N.C Punk
Old Jun 1, 2007 | 07:38 PM
Aardwolf's Avatar
Aardwolf
NAPA would have them, they are cheap. As far as I know they were stock. I can't remember witch side they clip on, maybe someone has a picture. Have you thought of getting a cheap Chilton's manual? It's not as good as the FSM but it does help out. I have both.
http://napaonline.com/masterpages/NO...re+Kit+-+Front
Two of the hardware kits would be needed. The pin was very worn on mine.
To rattling calipers
