Wire for choke...carb swap
What is an easy switched 12v source to tap into for my choke wire on my 86? Just trying to come up with something simple that will look clean.. I was thinking about just splicing a wire from the dist wiring but thought I'd ask for some suggestions first... anyone?
Did you ditch the computer and all the wiring?? If you just coiled it up (wiring that is) and placed behind the block tap a sensor wire ie EGR sensor..It is 12v keyed a good wire to use..I used a few for a bunch of things fan relay..fuel pump..Ect...I'm sure others who joined the "DARK SIDE" have other suggestions.....
