Erratic timing and idle only with EST connected.
#61
So acratch away!
WHAT "86 posted above"???
??? The question is... Why does one book say to change the weight, while another doesn't, with the same damper???
I checked, if you read the above post. It says the 1984 - 1991 C4s all take the same damper.
RACE ON!!!
Originally Posted by CentralCoaster
The 86 posted above doesn't have any, although there's one hole I can't see in the photos.
If the pin weight was to balance the damper, then the book shouldn't ask you to switch it to the new one.
You got the parts manual if you're so inclined to check. I'd rather scratch myself.
RACE ON!!!
#62
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The 86 damper pics posted by 86PACER that started this thread, you blockhead.
My 85 manual says nothing about any pins or reusing them. If the later manual does, with the same part, I would consider that superceding information if any early cars do have pins.
But I suppose GM saw a need to put pin weights in them at some point later on. Perhaps none of the early cars have pins to begin with, so the pin swapping doesn't apply.
#63
I have never come across anything like that before. I had written a different response assigning the difference to the 1986 and up dampers. Then as a double check, I looked up the dampers in my Corvette parts books. Contrary to my previous statement, all Gen I engines in all year C4s take the same damper. I appreciate the scan of the FSM. If I hadn't seen it, I wouldn't have believed it. This is a mystery to me. If the dampers were different I would write it off as just one more fact unknown to me, but the two different treatments in the FSM over the, supposedly same, damper has me totally confused.
As to Central Coasters comment, It would appear that a logical answer maybe that GM discontinued the added weight for a dynamic balance, through simply removing weight in the "heavy" spot to balance it. The damper 86 pacer showed, has an additional hole in it than my original..........so who really knows what the hail is going on here???
#64
Old damper has no weights. New damper has no weights. New damper's instructions say nothing about weights, nor does my '86 shop manual. The only thing the new damper came with was a new woodruff key.
Autozone has both the puller and install tool. Damper is in. All is well.
#66
RACE ON!!!
#67
Originally Posted by mseven
In context to the sentence I thought they were trying to say to: remove the weight from the "old" damper not the odd damper....if the spelling is correct (odd), are we to believe they were balancing each damper individually and some were just that out, or was it done as a complete rotating assembly?
Mick, Your damper should be neutral balanced, with the weight. Why is yours off, available for pictures? If your outer ring has spun, checking the balance won't work.
RACE ON!!!
#68
http://i7.tinypic.com/6cwsgzs.jpg
#69
I don't think any of the earlier cars have balance weight pins. If GM changed the part to include the pins, I would expect they would have changed the part number.
But with all that said, I'm 99% sure that it was just a renegade engineer on the chopping block that decided to make his legacy by added that little weight to aggravate purists and techies.
#70
well you may be correct, and for others following this thread and comments, here ya go.....as it turns out I had two different dampers put on a balancer today at a reputable machine shop that I know. The results were that the one w/the weight was very close to neutral balance (as CFI stated they all should be) the operater told me it was so close it wouldn't be worth "dinking" it. In addition it would take about 3 pin weights that size to throw out the balance. The other was a new OEM one I have for the car and w/out any weight added was at neutral balance....so it appears that GM does have a sadistic sense of humor...but I guess anyone with a vette knows that.
