Has anyone tried Bosch 22.5 lb. Injectors
Location: One day you're a Comet...the next day you're dust... Arkansas
Has anyone tried the pink top Bosch injectors in a stock L98? If so, how did they work out?
It would be nice to have a step by step guide to replace them. What NEEDS to be removed, what DOES NOT need to be removed. I have a leaky injector or 2 that over night my rail pressure is ZERO, so I know I need to replace them. Can do it myself, but a nice step by step would be great. At least a point to a post here that has the info.
St. Jude '03-'04-'05-'06-'07
Canoeman: use the search function, its been written before... Search, Advance, Archive posts and you should find what your looking for,,, also a FSM would be helpful...
Torx bolts
I am replacing my but waiting for the new bolts to arrive as I will not put the torx head bolts back. It would be a much easier job with normal bolts.
Ed
Ed
Here is a procedure on replacing the injectors in a L98 engine without removing the runners. This was requested in a comment above.
http://webpages.charter.net/buddiel/...al)%201-04.doc
This is a relatively simple job assuming you have basic tools and some patience
PS: I tried to place this in the "Tech Section" and was told this area is no longer maintained.
