H/VAC Question - Heat On All The Time
The short and sweet: 1986 Vette - I have heat coming from the AC & heater vents, all the time, controllor is set to off. AC isn't throwing any cold air when set to 60 and on Auto climate control.
I skimmed through the manual quick, but thought I'd start here since you guys usually have better info. I'm assuming I should isolate the heat problem before checking the AC. Can't say I know much about either system. Only thing I've checked is the vacuum line coming from the tank.
