Timing Chain Cover & Elec Water Pump
If I install an elec water pump on my LT4, Can I get a cover without the pump drive. Will a Gen 1 cover fit or must I plug the existing one.
You can leave the shaft in the cover or remove the shaft and plug the cover. I don't know if there is a cover without a hole for use with an electric pump. You could check with summit or other vendors to see if they have a cover. A plug would work fine and would be behind the pump and out of sight.
Bernie
Bernie
The thought of leaving the shaft sticking is out is to me a potential leak. Is a plug available or would I have to fabricate one?
Also, if I put on an SBC double chain, the driveshaft will have to go.
Is the cover stamped steel like a Gen I SBC? If so, I could weld it up.
This is what I did. Make sure the guy welding knows what he/she is doing because too much heat can distort the aluminum and cause premature failure on the opti seal.
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
1 Post
Eddie,
You can press the gear off the shaft whether you decide to run a double roller chain or not and just use the shaft thru the seal as an option like I did. You should not have any leaks as long as the seal is good and installed correctly.Welding does risk warpage and also prevents you from ever going back to a mechanical type pump in the future if the need ever arises without buying a new cover. Just food for thought. Just don't ever leave the driven gear installed when using an electric pump on a stock chain and gear to free wheel unloaded because you could have some serious tooth chatter,chafing, or gauling causing possible gear failure or breakage.Just my 2 cents.
Rick
Rick
