P/S Bracket fitment issues after decking block
Old Jun 30, 2007 | 09:41 PM
chucks88's Avatar
chucks88
Default P/S Bracket fitment issues after decking block
Since the power steering bracket bolts to both the drivers side head and the block down by the oli pan and timing chain cover....is it possible that the bracket will not longer fit in their proper holes after decking the block and resurfacing the heads.....or am I just overlooking something.
That thought occured to me to hog out the holes a bit in the bracket so I can get it to fit.
Old Jul 1, 2007 | 08:52 AM
chucks88's Avatar
chucks88
Ttt
Old Jul 1, 2007 | 08:56 AM
Slalom4me's Avatar
Slalom4me
How much will the heads be milled?
Although not speaking from experience, my vote is that there will be
enough tolerance in the brackets and fasteners that there will not be
a problem.
On an '89 the lower support comes together near the pump in a way
that permits a certain amount of swivel action.
Old Jul 1, 2007 | 08:58 AM
Pete K's Avatar
Pete K
That happens from time to time. If the holes were close to begin with, .039 head gaskets and decking the block and heads .030(combined) could result in an .040 difference.
.040 is quite a bit.
Old Jul 1, 2007 | 11:05 AM
chucks88's Avatar
chucks88
I'm not sure how much everything was decked/shaved. My 88's power steering pump bracket is a one piece unit and does not allow for any play/swivel to the block and heads. The only swivel point is on the bracket that connects the motor mount to the P/S bracket.
Funny thing is that the A/C bracket bolted up fine and that also is connected to both the head and the block(via the H2O pump)
Just got back from AUTOZONE and borrowed their power steering pump pulley tool. I'm gonna remove the bracket and hog out the lower mounting hole on the drill press.
Thanks for your insight boys,
Chuck
Old Jul 1, 2007 | 01:26 PM
chucks88's Avatar
chucks88
That did the trick I ran a 1/2" drill bit through the lower mounting hole and she bolts up just fine now.
Old Jul 1, 2007 | 06:10 PM
Slalom4me's Avatar
Slalom4me
Oops. Slalom4me apologizes for voting there would be no problem
for p/s bracket fitment after decking and shaving on your '88.
Glad to hear the remedy was straightforward.
Old Jul 1, 2007 | 06:18 PM
chucks88's Avatar
chucks88
You're fired
To P/S Bracket fitment issues after decking block
