serpentine belt model numbers needed please
hello fellas,
i have just finished up meaureing my two serpentine belts i will need.
iam after the " good year gator back " multi rib belt if possible please.
what does the different codes mean on each belt also please?
where can i find all different sizes and types of belts please ?
first belt length i need is between 66-67 inches,
with this belt i will be running alternator,power steering,crank shaft,water pump,pollution pump delete pulley, but i am deleting air cond all togeather and running the belt reverse around the idler pulley instead.
second belt i need is between 58-59 inches,
this belt will be running alternator,power steering,crank shaft,idler pulley ,no water pump as i will be running my csr electric water pump which i have but not ready to fit yet,also will not be running pollution pump delete pulley either and no air cond of course.
i hope some one can help please
thank you
regards
shae
thank you
regards
shae
What is wrong with Genuine GM??
A 6 rib 1698mm Genuine GM belt is Part # 10230259 (that is 66 and 7/8th inches on the off chance you failed maths)
That’s exactly what I need as well. But, I haven’t got any source yet, since I’ve long been with my Mercedes, so all I know are sources of my previous car’s parts like the Mercedes Benz Multi Rib Belt that I still have with me in my garage. The people here seems to be very friendly and approachable so I hope you could give me some idea of where I could find a good one, your usual dealer or whatsoever. Thanks guys, in advance!
