2 quick fuel quiestions on L-98 Need answer soon
I just need these two quiestions answered quickly please. Cold start injector. It is shot. It's in front of the throttle body correct? Would this make the car not start? It's been sitting for a day and now it cranks over but its not getting fuel. Second, I have spark, I took off a plug wire put a drill bit in it and put it on a piece of metal so it works. Plugs are all checked and in working order. Distributor pieces are all fine. Problem though. Is the fuel pump suppose to come on when you turn the key to the on position. Not start it but just on? If it does, mine is not making a sound. Yes, I do have half a tank of 93 octane in the car. I let the car get down to the 1 bar on the reserve tank, then filled it up half way. Is it possible the fuel filter is clogged? I always use premium gas so I don't think any dirt would get in there. Napa has a fuel pump and sock for 85 dollars in stock. If it's the fuel pump, then I can go ahead and get that. Im really leaning towards the cold start injector though. One thing, we checked all the injectors too. Looked everything else over while tinkering under the hood. It could be fuel pressure correct? If you guys say to, I can go get a gauge and check it. What does it need to be? Thanks, any informatioin is appreciated. Guess I am headed back out to the car now.
***NO, JUST HARDER TO START IN COLD WEATHER
***HAVE YOU ATTACHED A FUEL PRESSURE GAUGE TO THE RAIL SHRADER VALVE?
***YES, THERE IS A 2 SECOND PRIME. THERE IS FUEL PUMP RELAY ON THE FIREWALL BEHIND/NEAR THE BATTERY. THAT ENGAGES WHEN YOU TURN ON THE KEY AND IS BACKED UP BY THE OIL PRESSURE SWITCH/SENDER BEHIND THE DISTRIBUTOR.
***WHEN YOU TURN THE KEY TO ON, YOU'D BETTER HAVE 35+ - 45LBS OF FUEL PRESSURE AT THE RAILS.
***NOT AN ISSUE AS LONG AS TANK OVER 1/4 FILLED
***IT IS POSSIBLE
***NOT RELEVANT AS THE OCTANE OF THE GAS DOES NOT PRECLUDE ANY CONTAMINANTS EITHER IN THE GAS OR DROPPING INTO THE TANK ON FILL-UP.
***MOST LIKELY NOT THAT.
**SEE MY PREVIOUS POST - IF NO OR INCORRECT PRESSURE, CAR WON'T START.
***YES YES!...GET A GAUGE AND CK FUEL PRESSURE WITH KEY "ON"!
***IT IS POSSIBLE
***this is assuming you have a late 80's vehicle. ya need to post that info in your post or in your profile so that you don't get incorrect information!
To engage the Fuel Pump - connect a fused (+) lead to terminal G - (of the computer diagnostic port on drivers side just above the hush panel/gas pedal area) and apply +12vdc. This will cut the fuel pump on. This is a good thing to do when checking out a vehicle for purchase, since you need to check the codes anyway. This verifies that the pump is in working order.
Appreciate it. I used a paperclip. It made no sound. Guess, its the relay or the pump but I will check the pressure once I look around for a bit longer. Ill post back what I find.
Originally Posted by ~Cobra Killer~
Appreciate it. I a paperclip.
RACE ON!!!
What does that mean? As Da Mail Man said, to test the fuel pump you have to apply 12 volt power to terminal "G" of the ALDL. Regardless of whatever the above is saying, you can't do that with just a paper clip. Also, you could run a wire with 12 volts back to the fuel pump connector at the tank. HERE, is another post I made earlier this morning that may be of help.
RACE ON!!!
RACE ON!!!
Thanks guys. Ive been taking a break. I bought the gauge from autozone earlier. I have a voltometer here. How do I give it 12 volts? With a small battery? Voltometer? Sorry but I don't mess with wires. Ill post back later tonight what I find out. I am going to replace the fuel filter. The gas was down to the reserve bar and I suppose it couldve picked something up. I will do that first though before I check anything else because it is a must. I really appreciate the help. If there is something I can do to return the favor let me know. CFI, appreciate the link alot.
The year of your car would help a lot but to my knowledge only the early L98s had the cold start injector and it is not in the front of your intake, it's on the driver side between the intake runners. Nonetheless it is not your problem.
Look in my profile. I put it in there. Sjeez. I got a stock L-98 86. I had it on reserve YESTERDAY. I filled it with gas to the HALF mark point because I thought that was the problem. I said it could be the fuel filter because I let it get down so low. You told me that garbage can be added when fueling. I figured it mustve picked something up, if that is even the inital problem. I checked the fuel pressure. It says its 30...Possibly because the highest the gauge goes is thirty then underneath it in small red #s it goes up to -100. It's a fuel pressure gauge though. I am going by a Haynes manual. It has some pics and is allright in giving me some details. Thats why I was going to use a paperclip before like you do when you check for codes. It's hard to explain in words without someone being right here. Tomorrow I am going to get a fuel filter and replace it. I am going to cut open the old one to see what, if anything, is in there. I will go to NAPA for the right. parts. Thanks. My dinners ready as well. I'll wake up early tomorrow and see whats new. Thanks for the help. I'm so lost on this and I don't feel much like dealing with it.
....i've an 88 and i have a csv....
Look in my profile.
***I DID
I put it in there.
**IT WAS NOT IN THERE AFTER YOU POSTED AS I CHECKED
Sjeez.
***RIGHT BACK AT YOU
***AND SINCE YA DID, THE PROBLEM STILL REMAINS SO, FUEL LEVEL NOT THE PROBLEM.
***LOW FUEL LEVEL IN THE TANK WILL USUALLY NOT INCREASE THE LEVEL OF "TRASH" IN THE FILTER BUT, WILL ONLY CONTRIBUTE TO AN OVERHEATED FUEL PUMP OR AS A REACH, A PUMP SUCKING AIR (BUT USUALLY ON SPIRITED HARD TURNS).
***YEAH, IF YOU HAVE A LOT OF LEAVES, DIRT, AND SAND, ETC AT THE FILLER NECK BUT, YOU'D SEE THAT WHILE FILLING. IF YOU DIDN'T SEE ANY OF THE LIKE WHILE ATTEMPTING TO GAS UP, THAT PROBABLY IS NOT THE PROBLEM. THAT SHOULD BE A CLEARER EXPLANATION FOR YOU.
***SEE ABOVE.
***SO, WHAT YOU ARE SAYING IS THAT YOU HAVE A GAUGE THAT YOU CANNOT READ OR MAYBE THAT DOES NOT GO HIGH ENOUGH ? SO WHAT IS THE FUEL PRESSURE THEN?
**GET A HELMS MANUAL
***YOU ARE GONNA USE A PAPERCLIP? FOR WHAT? ONLY GOOD FOR PAPER AND GETTING CODES AND NOT MUCH ELSE.
***FOR WHAT? ...AND THEN WHAT?...IT'S AN EXCERCISE IN FUTILITY AND WILL SOLVE NOTHING BUT TO TAKE UP YOUR TIME AND INCREASE THE "DOWN" TIME OF YOUR CAR.
***I DID
I put it in there.
Sjeez.
***SEE ABOVE.
RACE ON!!!
Are you saying that the people you are soliciting free information from are bums because they haven't made the extra effort to go look at your profile for information that should have been in your opening post, in order to give you assistance out of the kindness of their hearts? Get real! Not many of us have to go begging to find deserving, grateful, people in need of help, that will be properly appreciative. Personally, I got enough info for the questions by the mention of the 9th injector. But for you to cop an attitude to someone giving help, because you think he is too lazy in his assistance to look up your profile for info that you should have included from the start, is the height of arrogance. As first responder, Da Mail Man gave you plenty of good information and help.
You didn't make that chronology clear the way you first presented it. Da Mail Man was perfectly right in being confused about how a half tank got down to reserve in a car that won't start. That is how you first presented it.
You bought the wrong gauge for working on EFI. Da Mail Man gave you the pressures to look for in his first post. If you bought the gauge since then, you should have known better. Also, you have the wrong manual. The Haynes can give some general assistance, but the FSM has trouble shooting charts for problems, such as yours, and descriptions of how various systems work.
Using a paper clip to check for codes is a great idea, but it won't help you in getting 12 volts to terminal "G" of the ALDL or the pump electrical connector. Don't go to NAPA, or anywhere else for parts, other than the fuel filter, until you have finished trouble shooting and you know EXACTLY what parts you need.
RACE ON!!!
RACE ON!!!
Originally Posted by Da Mail Man
maybe i , you, us, the forum, can let him slide a little bit after this spanking ya gave him? ...
RACE ON!!!
I don't see diiddly in your profile other than 1986. I also have an '86 but that wouldn't help much for asking advice. The guys here are more than willing to help those who help themselves
.....easy guy, let's not get this thing on "friday night at the fights" ...when i checked his profile and before i responded, he had "diddly" in his profile and nothing in his inital post...as cfi indicated, i also knew that his years fell somewhere between 86-89 because of the csv.....
I wasn't trying to bite the hand or be mean to the mail man. Sorry. It is difficult to interpet what I am saying thru internet. I really appreciate it. Ill post back tomorrow. I wasnt trying to provoke either. Sorry you guys took it the wrong way.
