Power Antenna Replacement
Looking to replace my power antenna. Where to get a new from? Corvette parts seller? Generic from auto parts store? Any brand/type I should avoid? Tips on procedure for replacing? It's a '87 coupe....
Thanx, -Pete.
Thanx, -Pete.
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you wanting to replace the entire antenna motor or just the mast? The C4's came with either Harada or AC/Delco motors depending on the year.
You can get the replacement masts from the dealer or Corvette parts catalogs for about $20 bones.
Recently the mast got stuck almost all the way up. Would not go up or down either by itself or with external help (me pushing/pulling). Motor continued to run and would not shut off. I had to resort to snipping the power line at the antenna. The cost of a generic is considerably less but I don't want to wind up with a headache trying to put it in. 'Originality' is not an issue. I checked ebay, found one that says it's the GM replacement part for '84-'87 and requires some modification but doesn't explain.......
I needed to replace mine but didnt want to spend the money. I bought a universal stubby antenna from Car Quest for $15. I then bought a female to female antenna adapter from Best Buy for $12. Works just fine and dont have to worry about the antenna going out again.
