1984 Single Turbo by JoBy continues
#66
#68
Awesome work man, alot of skill and dedication to take the idea in your mind, then create something tangible that will haul ****
Hey Joby how close is that exhaust crossover from driver - passenger under the oil pan? Did you heat wrap it & or use somekind of heat shield? I 'd like to use block hugger headers, then do an under oil pan crossover to a 3" single exhaust or use a 2x4 tube, currently scrapping the floor over railroads and speed bumps. Feed that exhaust into a rear mount turbo & then bring the intake up through by the inner chassis frame rail ( heater fan assembly already gone) then straight shot to engine, 750 carb.
#74
Congrats! The setup looks great!
#79
That thing is getting it done for sure. 135 MPH trap speeds are no joke.
What's you combo again? Stock L98 short block, better rod bolts, modified stealth ram, and XX boost? Right?
#80
Actually L83 (Cross-Fire) but the short block is the same as 1985 TPI.
Stock engine block.
Stock crank.
Stock rods.
Stock pistons.
ARP bolts.
CompCams 12-404-04 cam (LSA 114, duration 222/225 @0.050, lift 0.464/0.464
CompCams 858-16 Pro magnum Hydraulic lifters
CompCams 1412-16 magnum roller rocker arms
AFR 190 heads with 74cc chamber size.
Holley Stealth Ram that I modified to clear the stock hood.
Haltech E6K
120 lbs injectors.
SX fuel pressure regulator.
Twin BOSCH fuel pumps and a surge tank in the rear right fender.
Dana44
4L80E controlled by a TCI T-Com
Vigilante converter
Front mount XS Power intercooler with 24"x12"x4" core.
HKS 'style' 50mm wastegate
Garrett TBP7501 turbo from a Volvo wheel loader
E85 ethanol fuel.
Stock engine block.
Stock crank.
Stock rods.
Stock pistons.
ARP bolts.
Haltech E6K
120 lbs injectors.
Dana44
Vigilante converter
E85 ethanol fuel.
