Discreensd Maf!
Old Jul 25, 2007 | 03:50 PM
Phatoscar's Avatar
Phatoscar
Default Discreensd Maf!
I discreened the MAF because I came across one for 20 bucks I think it came out of an Iroc or something. But I bought it and discreened it! And the gains were amazing I think for a free mod! My car is a 1986 automatic and also has K&N, Cut Air Lid, TB Bypass, Mild cam, .030bore, forged pistons, clevite bearings, Roller timing chain, Msd wires, Magnaflow High flow cat, lt mufflers, and a rebuilt tranny! Before it was fast but now I can be cruzin and at about 15mph and floor it and the tires will chirp at the point of down shift! Im Happy!
Old Jul 25, 2007 | 03:58 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Old Jul 25, 2007 | 04:02 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Old Jul 25, 2007 | 04:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Was the MAF you removed bad?
Old Jul 25, 2007 | 04:08 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Must have been,,, descreening does not increase HP like that....
Old Jul 25, 2007 | 04:09 PM
Phatoscar's Avatar
Phatoscar
No! But the one I got looks to be alot newer!
Old Jul 25, 2007 | 04:11 PM
CentralCoaster
Removing MAF screens increases HP due to a scientific phenomenon known as the placebo effect.
Old Jul 25, 2007 | 04:21 PM
IBVETN2's Avatar
IBVETN2
I couldn't really tell SOP when I descreened mine. Maybe I need one from and IROC to try.
Don't put too much oil on your K&N now or it will load up the wires and take the tire chirp back out of it.
nogoodsam's Avatar
nogoodsam
I'm glad you found some improvement (whatever the reason) !!
However, your gonna receive a lot of slack for this one.
Old Jul 25, 2007 | 04:23 PM
LT4BUD's Avatar
LT4BUD
Also the removal of a significant restriction, ie reduced cross-section, helps too.......more than a placebo....
It depends, but somewhere around 5 hp gain is probably realistic..
My screen is gone....no SOP when I removed it......no before and after dyno......no before and after track times......but visually it was a good thing to do......and again I doubt, but don't know for sure, whether it screwed up my laminar flow......but my motor does run pretty good!!
A great mod considering it is FREE!! but just my humble opinion...
Old Jul 25, 2007 | 04:26 PM
NEVRL8T's Avatar
NEVRL8T
If you get 5 HP gain out of a descreened MAF - then monkeys will fly out my butt.
black96lt4c4's Avatar
black96lt4c4
this intake tract thread is cotroversial to say the least.the cut lid,k&n vs. paper,and the maf screen removal debate is interesting and deserves another shot.is it possible there was a problem with the original maf with the screen? i would never ? a members post of performance gains,thats what this forum is here for.is the screen to catch "debris" in case of a broken filter or plastic housing?how can debris large enough to be caught by the screen make it past the filter?if the screen was condensed,what would the actual area be?1/4 inch or 2 inches for example.just wondering.junior
Old Jul 25, 2007 | 04:27 PM
TheCar's Avatar
TheCar
Didn't waste my money on a K&N cause when I go to the track I throw the air filter away. Thats why I left the screen in too.
Old Jul 25, 2007 | 05:24 PM
Phatoscar's Avatar
Phatoscar
Well I do have a AF gauge and it does read diffrent with the discreened MAF! Before it use to read right above the stoichemetric point and know it reads about half ways throw the rich point!
Old Jul 25, 2007 | 05:28 PM
Road Agent's Avatar
Road Agent
Old Jul 25, 2007 | 06:22 PM
NEVRL8T's Avatar
NEVRL8T
On an LTx engine removing the MAF screen is a waste of time.
Old Jul 25, 2007 | 06:46 PM
LT4BUD's Avatar
LT4BUD
Not really......it helps reduce the weight of the car and we all know a lighter car will perform better!!!!!
To Discreensd Maf!
Old Jul 25, 2007 | 07:11 PM
Phatoscar's Avatar
Phatoscar
That was my main motive!
Old Jul 25, 2007 | 07:18 PM
kanigit's Avatar
kanigit
3rd Gear
This article posted a few days ago says that removing the screen will help increase air flow. http://www.corvettemagazine.com/2000...ldup/l98p1.asp
Note that it was part of additional mods including K&N filter.
Old Jul 25, 2007 | 09:43 PM
CentralCoaster
Will that show up on the butt dyno?
