Stroker rod-cam clearance
Old Jul 28, 2007 | 06:16 PM
corvette90's Avatar
corvette90
Default Stroker rod-cam clearance
Hi
just wanted to ask...
i run these rods in my 396 Stroker..
http://store.summitracing.com/partde...T&autoview=sku
would they work with a "normal" camshaft, or will i have to get a small base circle cam?
thank you
Old Jul 28, 2007 | 08:51 PM
CFI-EFI's Avatar
CFI-EFI
I would think there is a good chance they will clear, but I would ask Eagle, directly.
RACE ON!!!
Old Jul 29, 2007 | 01:13 AM
mykle's Avatar
mykle
The description says that they aren't clearanced for a stroker.
I kind of got caught up in the topic because even though they say they aren't clearanced they sure look like they would clear just fine.
Ends up I was right and so was the description. They will work...just not in a 396.
http://cgi.ebay.com/ebaymotors/SBC-3...spagenameZWDVW
But, do call them and get it from the guys who really know.
Old Jul 29, 2007 | 04:15 AM
corvette90's Avatar
corvette90
Hi!!
i have special stroker clearanced rods p/n CRS(ESP) 6000BST, i bought them directly from eagle..did use a small base circle cam on my last built, but i really think its overkill...
also, just go to the bottom of the page in your ebay link...the rods, they are referring there, are the ones, i run...
i will, like CFE-EFI mentioned give them a call..unfortunately the eagle homepage seems to be down at the moment...
thank you
Old Jul 29, 2007 | 02:52 PM
Maximus9000's Avatar
Maximus9000
From the Eagle web site.
Old Jul 29, 2007 | 03:10 PM
corvette90's Avatar
corvette90
thanks, Maximus9000
that are the rods, i´m currently running. CRS6000BST..so, still the question..will the clear a normal base circle cam?
i really think, they should...
it seems, nobody ever built an engine with them...
Old Jul 29, 2007 | 06:35 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
On my 398 - 3.875" stroke x 4.040"bore - first time around I used a Comp .900" base circle solid roller cam with the regular Eagle 3D rods with no clearance problems cam wise. This time around went with much more aggressive cam lobes - very similar durations, same .900" base circle - and had to clearance the shoulders of the rods for clearance. It wasn't a base circle clearance problem, but clearance at the flanks of the cam lobes.
Unless somebody's put together your exact combination you're not going to be able to get a definite answer.
Old Jul 29, 2007 | 10:15 PM
Maximus9000
Those are the rods I'm planning to use on my build.
I believe these are the rods that are included in the Eagle forged rotating assemblies with strokes starting at 3.800 on up.
Old Jul 29, 2007 | 10:17 PM
Maximus9000
corvette90
are they clearanced on the one side only, is it obvious that they have had some material taken off?
Old Jul 29, 2007 | 11:16 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Here are the rods I use with a 3.80" stroke. Plenty of cam clearance with a Hotcam.
Eagle lightweights
Old Jul 30, 2007 | 04:28 AM
corvette90's Avatar
corvette90
Originally Posted by Maximus9000
corvette90
Hello!!
yes, they are machined quite good on one shoulder...
here´s a pic of them: http://www.cnc-motorsports.com/produ...18&CtgID=14112
Old Jul 30, 2007 | 10:42 PM
Maximus9000
Wow, those Featherlight H-Beam Rods are 100g lighter but only a $100 more.
How much do you think that 800g difference makes in the revs?
To Stroker rod-cam clearance
