Difference between a LT1 cam core and traditional SBC cam core?
On the 95/96 LT1, the pin drives the opti. On the 92-94 the opti is driven off a splined shaft that inserts into the upper timing gear.
The difference IS the pin length and for a Gen 1 block you cut that pin's length I believe in half. It's been a few years so I don't exactly remember the length you cut it to, .375" kinda rings a bell.
The cores are the same (meaning bearings and lobe placement). There are some subtle differences that will vary from cam to cam - distributor gear, fuel pump lobe, and the dowel pin already mentioned.
Ok because COmp cams will not custom grind an LTx solid roller cam, but have a 4/7 swap available for a traditional sbc. Im using an electric water pump and no optispark so a regular sbc cam should work fine. Thanks for the input !
whoa! it doesn't matter to you since no more opti, but for future reference when other people do a search:
the late opti requires the LTx core. the LTx core has a large hole bored into the nose. the opti shaft goes through the cam sprocket and into the cam's nose.
-michael
-michael
