What lube is best for '94 LT1 differential (rear end)?
Most shops seem to recommend the factory fill oil and friction modifier for the rear end. Longer life and good performance. One shop that does nothing but rear end repairs said to avoid sythetics if you want longevity. I tried RedLine 75W-90 on two vehicles (Ford PU and Toyota 4Runner) in the past and the pinion bearings wore out prematurely on both. Factory fill the best?
St. Jude Donor '03 & '05
GM's oil and additive are just fine I am sure, unless racing in road racing etc, where temps can be a problem.
Mobil 1 here with 1 can of posi additive. Has held up to several years of street and roadracing. I had never heard of a problem using it with Right Stuff but you never know.
Mobil1 gear oil is a consumer product and not quite as good as Mobil's Delvac 75W-90 synthetic which is more performance oriented. I'm still gun shy of any synthetic for my '94 though.
Premium Supporting Vendor
Been running AMSOIL Synthetic Manual Transmission and Gear Lube 75w90 in my 02 Z06 on the track for years without issue.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
I used the Mobil 1 and 4oz of posi juice after I rebuilt my D44. I wore out two rear ends in my Mustang with the Redline stuff they say is so good. I'll not be using any of that again. I'm not saying thair stuff is bad, but I didn't have any luck with it ! I've never heard anybody say ANYTHING bad about any Amsoil product, so I'd say go for it. I would have used it, but I was in a bit of a hurry when I put mine in and didn't have quick access to the Amsoil...so Mobil 1 went in and seems OK.
The only thing synthetic I run is the engine oil and depending on the car the power steering and brake fluid.
For my 89 Vette I used the factory fill in the ZF and in the Differential. The differential works perfectly, and once the ZF warms up it shifts like butter. I will probably change the trans fluid every 20K and the Diff every 30K so I am not too worried about it breaking down.
DG
DG
C4 of Year Finalist (appearance mods) 2019
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I've had no problems using the factory recommended lube and additive.
Something else may be cheaper, and/or just as good, but I don't see how it could possibly be any better.
Larry
code5coupe
_________
not easily impressed....
Larry
code5coupe
_________
When I was in school my professor used to always say the same thing every time I had a bolt or two left over after a project.
"GM put that there for a reason."
I feel similarly about servicing the vehicle. Synthetics have a few qualities that make them suitable for engine use and a few other uses, but overall you can't go wrong with the factory fill on factory parts. I have yet to hear someone identify the cause of failure in a factory differential as bad factory fluid. Yet, posi's burn out all the time on synthetics such as mobil one. Most of us will never experience these problems. I notice alot of guys who have posted good results using mobile 1 swear that 100K+ miles and no problems. You could run the diff on water and it would probably live, but why risk it. Dollar for dollar Mobil 1 is about the same price as a qt of factory fill. No performance benefits... really no longevity benefits, why bother??
Just my $0.02, I like to play it safe, what can I say,
DG
DG
