Cam change in car or out
[QUOTE=tequilaboy;1561550619]It is also possible to do with the intake still installed with some creative use of pen magnets:
I did have to pull 1 motor mount bolt and jack the engine slightly for the cam to clear the cross-member, but it was not a problem at all.[/QUOTE
Left or right? driver's side or pass?
Changed the cam in my 1990 once while it was in the car. After the cam change we pulled the heads to replace those too. Found a cracked piston, pulled the pan, and found several bad rod and main bearings. Had to pull the motor anyway after all that.
Since the motor was out, turned it into a 383 and never looked back.
did a cam swap, valve springs and seals in the car. not difficult but a series of finite steps most (all?) labor intensive; take your time and don't try to do too much at any one time and you'll be fine.
