Rear Spring Bushing Question - On the job now
In the middle of replacing the rear spring on my car. Of course I am getting come grease on the key board!
I ordered the VBP poly bushing kit for the rear spring. The problem is this... I have two different sized bushing in the kit. The originals appear to be the same size. So I have
Two big ones part number A3-1320
Two small ones part number A3-1321
I am guessing (semi-educated) that the top one is the smaller A3-1321 as it seems to fit in the better there... and the big one goes under. I know it probably will not matter much but I need to do it right...
Before I go forward anyone run into this? Advise? I am going back out to replace the left rear caliper and rotor.
I will check back in an hours or so....
Yes, I realize this post is a year old.... HOWEVER..... I found it through a Google search and was glad I did. I had no idea of the orientation of the small/large bushings. I tried searching what seems to be the now defunct VB&P and no luck. So again, thank you Corvette Forum!! Hope someone else can use this information as well.
