Octane Booster for Pinging?
My car is pinging, and I don't know what it is, maybe knock sensors, will adding octane booster stop the pinging, and is it dangerous to use as a fuel additive? Thanks, Suke.
Cruise-In II Veteran
Re: Octane Booster for Pinging? (C4 Suke)
An octane booster might cure the symptom but mask the problem.
Look at timing, EGR function and A/F ratio. When my knock sensor circuit is functioning properly I can't hear ping though I can see knock counts on the scan tool.
Re: Octane Booster for Pinging? (65Z01)
I know someone with a Snap-On scan tool, I think its a scan tool, it works with like a lot of cars, is that what you are talking bout when you say scan tool? It has a wire harness that hooks up to the Vette under the driver side dash.
adding octane boost will undo the problem... but you dont want to use octane boost for everytime you fuel up that would be a pain. you should see if your timing is off maybe to advanced?
So how would I exactly use one of these tools, hook it up and just write down the a/f ratio, egr function, and timing and then post it up here for you guys to evaluate :D ? Do I drive the car with the scan tool on so I get values while driving?
[Modified by C4 Suke, 9:51 PM 11/6/2001]
The method depends on the functions available. My AutoXray has a "Monitor Mode" that gathers values of all data parameters at one second intervals over 30 seconds with a trigger midway. This allows me to start out at idle and drive through the engine conditions of interest while gathering data. Then I enter the data into a spread sheet for study. Sometimes the cause of a problem just jumps out; other times it takes some study.
