The Official Exhaust Resonance Post!
Old 08-22-2007, 11:57 AM
bogus
CF Senior Member
there is one more factor... the design - ie acoustics - of the cabin. it's a resonance chamber!
do a little insulating should help.
bogus is offline
Old 08-22-2007, 08:09 PM
cuisinartvette
CF Senior Member
St. Jude Donor '05
Doing GOOGLE, it looks like 121-C / 250F,, so exhaust at 250F, I doubt very very highly that the exhaust reaches this temp at the exit of the muffler.
No worries
cuisinartvette is offline
Old 08-22-2007, 09:02 PM
LD85
CF Senior Member
LD85's Avatar
A bag of Steel Wool cost be $1.99 at Home Depot, I take 4-pieces and unroll two of them and wrap them around the other two pieces, the push it into one side of the exhaust.
So this is the end result, resonance gone,, lost maybe 2-5 hp,,,
for me no issues,
Reversible, pull it out when you go to the track but on the street, you wont miss 2-5 hp.
LD85 is offline
Old 08-22-2007, 11:11 PM
touringmike
CF Senior Member
touringmike's Avatar
What is this "resonance" of which you speak?
touringmike is offline
Old 08-23-2007, 12:02 AM
coupeguy2001
CF Senior Member
coupeguy2001's Avatar
Default tires
hey mike we didn't say show us your bootie
coupeguy2001 is offline
Old 09-07-2007, 01:07 AM
jakers
CF Senior Member
jakers's Avatar
St. Jude Donor '06
Default Anyone else?
Have input on this for the books?
jakers is offline
Old 09-07-2007, 01:43 AM
cuisinartvette
CF Senior Member
St. Jude Donor '05
its a short exhaust system to begin with and mufflers being the exit with no tailpipe afterwards makes the chances of resonance real high if something is changed.
Old 09-07-2007, 01:44 AM
steve40th
CF Senior Member
St. Jude Donor '03 & '05
True. If you insulate the rear cabin, it will reduce it. When I put my roll bar in, S/T Frame, the holes cut into the interior werent insulated till I got home. I thought I had open headers. I have heard you can get rid of allot of the noise through insulation. It wont cost much, actually, as there isnt much back there, in our hatch area.
Of course gears help, as you will not be in that rpm range often
steve40th is offline
Old 09-07-2007, 07:28 AM
runner140*
CF Senior Member
Support Corvetteforum!
runner140*'s Avatar
I have two Magnaflows with stock resonator and stock cats with the tipe extended past the bumper. I do have resonance at 1000-1500 rpm's.
runner140* is offline
Old 09-07-2007, 07:50 AM
BerniesVette
CF Senior Member
BerniesVette's Avatar
Hey lt4obsesses,
I had a local shop remove my mufflers and the sound is great but the resonance is terrible in city traffic. You wouldn't have the part number of the magnaflow muffler you used would you? I think that is what I need!
Bernie
BerniesVette is offline
Old 09-07-2007, 08:29 AM
ps374
CF Senior Member
Why couldnt Chevrolet just have come up with something like they did in 1962 called Off road exhaust system, and just give C4 and C5 owners a specific sound which would stop all this tension of trying to get their exhaust system right.The closest I ever heard a car have that specific old Corvette sound was my sons 85 Z28 with headers and one flowmaster muffler which sat in front of the rear axle, And there was NO resonance at all. My 84 has flowmaster 40s with gutted cat and does not sound as good as his car and the resonance is very loud.His did have a 305 if that makes any difference?
ps374 is offline
Old 09-07-2007, 10:54 AM
dclafleur
CF Senior Member
dclafleur's Avatar
Does anyone know if switching to the mass backed carpet replacements from wilcox helps with the insulation? Or do you really need a layer of acoustic insulation in there too? I really think dampening the sound in the interior is a large part of the key to reducing resonance. The interior on my '85 transfers so much sound on the highway and I know a lot of it is road noise too, not just exhaust.
dclafleur is offline
Old 09-07-2007, 11:03 AM
  #33
cuisinartvette
CF Senior Member
St. Jude Donor '05
Mass backing will definitely help as opposed to not having it.
Magnaflows will still resonate btw.
Old 09-07-2007, 01:48 PM
  #34
RacerX70CC
CF Senior Member
RacerX70CC's Avatar
My solution... (not eliminated, but GREATLY reduced)
RacerX70CC is offline
Old 09-09-2007, 03:24 PM
  #35
cuisinartvette
CF Senior Member
St. Jude Donor '05
Resonance between 1100-2000 is bad. Even in this clip when Im just crusing the rpm range is well above that and still booms...
This is with dual 3's, dual dynomax "bullet" resonators and Dynomax super turbos. Bet with a smaller pipe it would be more manageable.
[/url]
Old 09-09-2007, 04:07 PM
  #36
LouisvilleLT4
CF Senior Member
LouisvilleLT4's Avatar
About the steel wool trick... doesn't steel wool rust like crazy when you have it in a hot, occasionally moist place like the mufflers? Wouldn't that rust spread to the mufflers? Or is there some sort of "stainless steel wool" you can buy?
LouisvilleLT4 is offline
Old 09-09-2007, 06:49 PM
  #37
crossfire84
Junior Member
crossfire84's Avatar
Default steel wool installed
I tried the steel wool trick years ago. On my car, I had a set of smittys and scavenger pipes, and got a noise ticket. So I poked steel wool up the pipes, (drilled holes in the pipes to hold the wool in them) and drove to the other town to get signed off. It worked, and Man it was quiet!! It was neat dark when I left and so I pushed it up to the neat triple mark. I passed this car, and got about 50 feet ahead of him, and two great big ***** of burning steel wool rolled out and scared the living crap out of us. Yes steel wool will get hot and glow from really hot exhaust. That my lesson
crossfire84 is offline
Old 09-09-2007, 09:02 PM
  #38
Lilred87
Junior Member
Lilred87's Avatar
PS374 may be on to something. Has anyone tried to come straight off the cat with a single flowmaster or Magnaflow with the built in x pipe
and dual outputs to run to the back. It would be similar to a eliminator setup with one muffler. Would that be too restrictive?
Lilred87 is offline
Old 09-09-2007, 09:18 PM
  #39
LD85
CF Senior Member
LD85's Avatar
Mine is always coated with black carbon, so, no, I have not seen any rust on the steel wool
crossfire84 = "two great big ***** of burning steel wool rolled out and scared the living crap out of us. Yes steel wool will get hot and glow from really hot exhaust. That my lesson" No way your exhaust got up to 250f
LD85 is offline
Old 10-14-2007, 12:56 PM
  #40
jakers
CF Senior Member
jakers's Avatar
St. Jude Donor '06
Default X pipe
Would like to hear a bit more on x-pipe experiences! The effects on sound and resonance!?
jakers is offline
Quick Reply: The Official Exhaust Resonance Post!
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
