How do I set the timing?
Hello friends! Just need to set the timing on my 1991 stock L98. Just resealed my intake and wanna make sure its where it should be.
Thanks to all.........
On the driver side near the brake booster, find a tan wire with a black stripe. Plug looks like an O2 plug. Unhook it. Start car and set timing at 6*. Turn off car and hook it back up. Done.
......i agree however, as i don't recall, does that not set up a code that has to be cleared?
Originally Posted by Spankyellow
On my 87 its a soft code. Its in memory but does not give a service engine light. After the car is driven a few times, it goes away.
Disconnecting the tan/black stripe and starting the engine will also set a code on my 89. To remove the code, disconnect the negative battery cable for about 30 seconds and reconnect it.
