Anybody Running a 400 small block?
Re: Anybody Running a 400 small block? (No Go)
I paid $250 for my block.. this included the following tests performed on the block
Hot tanked
Pressure tested
Sonic tested
I was even told that if I really wanted I could run a standard bore, I think the car it came out of had 27K miles
Hot tanked
Pressure tested
Sonic tested
Re: Anybody Running a 400 small block? (-=Jeff=-)
Jeff,
[QUOTE]
1) Not completely true. There are some 400SBC with only 2 freeze plugs per side. Mine is one of them.
2) As for the dipstick, I have been told you need to move it to the Passenger for steering clearance issues. That is what I plan to do.
1) Yes, I have seen some 400s with only two freeze plugs per side. They DID, however have a flat area in the casting where the middle freeze plug would be located. I've never seen either condition on a block that wasn't cast for a 4.125 bore. I was trying to keep things simple. If you spot a core at a bone yard or a swap meet, etc. and it has three freeze plugs per side, you will KNOW that it's a 400.
2) I too would prefer a right side dipstick. I don't want to give anyone any reason to think it's not all factory. With the hole in the block and the jog in the rail of both the pan and the block, I never even considered that it COULD be relocated. Do you know of a proceedure for this? If feasable, I want to do it too. I had just planned on telling anyone who noticed, that the block had frozen and this is what was available to replace it with.
CFI-EFI
[QUOTE]
CFI-EFI
Re: Anybody Running a 400 small block? (CFI-EFI)
That is all the info I have
Well all I know is that the Machine shop I used for my 355 said it can be done, I have also seem someone do this on a 350.. they redrilled the Pass side and the new gasket covered the hole on the Driver side. he also used a passenger side dipstick Pan..
CFI-EFI
GM makes a block with no dip stick hole and you put it where you want it. To see ad go to paceparts.com Don't know why someone would want to go to all that trouble though unless they plan on cheating in some form of racing :lol:
Re: Anybody Running a 400 small block? (KYVette90)
Somebody mentioned cooling. I just thought I would point out that my friend finally got his Z-28 running. It is a 396 stroker, it stayed right at 160 degrees all the way home. With a good clean radiator, good quality coolant at
the proper mixture, and a computer program to help with the fans, cooling shouldn't be an issue.
Dipstick Tube
I am running an early 70's casting with drivers side dipstick tube. I didn't have to bend or pry it at all. FWIW, I was told it was from a Monte-maybe different dipstick tubes for different cars...but probably not.
Anywho, no problems (just the fact that my oil pan sits about 3/4 of an inch lower and I have had to pull the pan off to weld some unfortunate scrapes from the driveway). -Matt-
