Anybody know this info or where I can get it?
I want to find out a little more about my engine 1994 LT1...
1. Bore and stroke
2. Valve diameters
3. Camshaft lift
4. Type of lifters
Thanks :chevy
1. Bore and stroke
2. Valve diameters
3. Camshaft lift
4. Type of lifters
Thanks :chevy
Re: Anybody know this info or where I can get it? (jay17)
Here's your info your looking for:
LT1 Specs:
Block: Cast iron, short skirt
Bore x Stroke: (in.) 4.00 x 3.48
Displacement: 350 cu in, 5733 cc
Crankshaft: Cast iron
Torsional Damper: Single mass
Main Bearings: Center Caps 4-bolt, End caps 2-bolt
Connecting Rods: Powdered metal
Pistons: Eutectic aluminum/silicon alloy (Mahle 142)
Cylinder Heads: Aluminum, 2 valves/cylinder
Valve Diameter: Intake/Exhaust (in.) 1.94/1.50 2.00/1.55
Rocker Arms: Conventional
Valve Springs: Round Section
Cam Drive: Link chain, powdered-metal sprockets
Valve-Open Duration: Intake/Exhaust (in.) 279/276
Valve Lift: Intake/Exhaust (degrees) 0.447/0.459
Valve Overlap: (degrees) 41
Compression Ratio: 10.4:1
Fuel Injection: Electronic sequential port
Fuel Recommendation: Premium Unleaded
Ignition Electronic: platinum tip spark plugs
Horsepower: (hp @ rpm) 300 @ 5,000
Torque: (lb-ft @ rpm) 340 @ 4,000
Redline: (rpm) 5,700
Hope this helps you!
LT1 Specs:
