Attention Supercharged & Turbocharged Corvette Owners - Alcohol Injection Systems
Former Vendor
Location: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
ATTENTION SUPERCHARGED & TURBOCHARGED CORVETTE OWNERS:
No supercharger or turbocharger system is complete without a water methanol / alcohol injection system. Regardless if your running an Intercooled system or not. The benefits gained from a water alcohol/methanol injection system on both Intercooled and non-Intercooled supercharger & turbocharger systems are so significant, you simply can’t afford to run without one once you realize the benefits gained by using it.
Benefits of Water Alcohol/Methanol Injection:
- Lower air temperatures by 50-250+ degrees
- Reduces cylinder temperatures by 250+ degrees
- Increase your 87-93 pump gas by 10-20+ points
- Increase horsepower safely by 8-15%
- Allows you to safely run more boost and timing
- Longer more stable combustion expansion and progression
- Removes carbon build up from combustion chambers, pistons and valves
- Reduces & helps eliminate damaging engine detonation & pre-ignition
- No need for expensive racing fuel or additives
- Cheap insurance for supercharged and turbocharged gas applications
This is particularly important on supercharged and turbocharged Corvette’s with factory compression ratio’s ranging between 10.0:1 and nearly 11.1:1. Adding boost on top of such high compression and non-forged pistons and internals further raises the concern for engine damaging detonation and taking extra measures to prevent it.
Adding a Alcohol Injection System can significantly reduce and help eliminate this potential engine damaging detonation caused by superchargers and turbochargers while increasing horsepower at the same time.
Protect your engine and the investment you have in your engine while increasing performance at the same time.
Click below to view various kits available.
AIS Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System
AIS Stage 2 Digital Progressive Trunk Mount Water Methanol/Alcohol Injection System
[IMG]http://www.alcoholinjectionsystems.com/images/customers/corvette_alcohol_injection5
Former Vendor
Former Vendor
Former Vendor
