HELP! Power sport seat removal, how?
My passenger side power seat in my 91 is stuck and i need to remove the seat to see what's prevent the seat from moving forward but i need to remove the seat 1st and i can't find and information to help me complete this seat removal, do any of you forum members have any idea how i can remove my seat?
thanks boonie
thanks boonie
Right in the middle of the very front of your seat bottom (at the bottom), you'll find a spring clip which holds the bottom in place. Pry that off and your seat bottom will just pull out.
The problem with the seat is that the gear assembly does not work properly. I have had these apart and what happens is the bearing supports break and it lets the gears separate and not mesh. The gears itself do not go bad. So they click and not move.
I have done internal repairs on them but it usually does not hold up. I ended up replacing the entire assembly on the driver side, and did some what of a repair on the passenger side. I wanted the driver side to be perfect.
Remember that both seat tracks are the same part number. If your passenger side works good and the drivers side doesn't, then swap them.
I think you can then manually move the broken (passenger side) in the full back position and leave it that way. It only the drivers side that really needs to be adjustable.
