need help on tuning accel calmap gen 7
Hi,
I am new to this forum and need some help on tuning. I have just rebuilt a 400 small block and have installed it in a 85 corvette, 30 over, 4340 scat crank and rods, speed pro hyperutenic pistons, TPIS intake, 1160 throttle body, 42 lb injectors, comp 600 lift cam and roller rockers, edelbrock heads, an acecel dfi gen 7 stand alone system, I have just purchased a wide band for it. Headers, 11 to 1 compression ratio. I have not dyno tuned it yet but I suspect it is some what north of 450 hspwer at the flywheel. The installer has done a pretty good job of installing and setting up, but I need a killer tuner who is really good with the accel gen 7. As long as he is on the west coast anywhere west of Utah. Any suggestions would be gladly received.
Thanks,
Wayne Nelson
Thanks,
Wayne Nelson
CI 5 & 8 Veteran
So, Wayne, Did the installer set-up your wideband O2 when he did the installation? Have you looked at the A/F readings at various VE cell positions in open loop to see how far off base you are? If you are not running sequential, and don't plan to, you can come pretty darn close just driving the car around with a passenger seat tuner. You can also run some data logging runs and post them for help. I haven't tried the remote connection capability that Accel Gen VII offers, but if you do have access to a dyno it is possible to do a web based tune using a remote expert over conference. That would be interesting to try IMHO. If I can help in anyway let me know, unfortunately StL Mo. is on the wrong side of the Rockies.
Bullshark
Bullshark
wide band
We have not set up the wide band yet. The Eccel came with a narrow band. We have the Accel distributor and have set the system up with sequential injection. The car runs high 12s with street tires at 4500 ft
but I feel that there is 20/30 horsepower left in the motor/tuning
CI 5 & 8 Veteran
Bullshark
Ron
accel tuning
Ron, thanks,
I have been recommened Tom from Portland. I have gen 7 system I have is 3 years old, so before I go to Portland I am going to have the box upgraded, when I get that back I will install the wide band, and make a quick trip to Portland for a strong dyno tune. There are some things I want to have done that I think is beyond my ability.
Wayne
Wayne
